slipping trany
Old May 16, 2014 | 08:17 PM
starrbright40's Avatar
starrbright40
Angry slipping trany
hi i have a dodge ram sport 1500 5,9l an a week ago my truck started to slip in 2nd gear i need help
Old May 16, 2014 | 08:56 PM
OK, I'll move you to the correct section. Spend a few minutes reading what each sections purpose is before posting. This section is for reporting issues with the Dodge Forum internet site.
Old May 17, 2014 | 08:26 AM
starrbright40
Default slipping trany
where did you move me can t find it so i can see replys
Old May 17, 2014 | 09:15 AM
i4got68's Avatar
i4got68
2nd Gen Ram tech
Old May 17, 2014 | 09:44 AM
Probably a good first step would be to drop the pan, and see what you find. The governor solenoids in these are not self cleaning... so, they can get clogged up with crap, and stop working right. Might be able to just change the solenoid and sensor, and be good to go for a while. Or, it might be getting on toward time for a rebuild. Gotta take a look, and see what ya got.
Old May 17, 2014 | 11:55 AM
master tech's Avatar
master tech
Site Moderator & Tech
Is the check engine lamp on? And if it is, what are the codes. If the lamp is not on, then I would remove the pan and check for debris. How is 1st and 3rd gears? The front kick down band maybe loose or missing and kick down strut.
Old May 17, 2014 | 02:27 PM
starrbright40
it has at least 193.oo0 miles . i took it to ammco an they said they could not tell in lese they droped pan an take it apart . i also took it to some one else an they said it was backfiring an it was not the transmission but i thought the code light needs to be on to show if it bad .also can there be a sensor in the engine that acts like the shifting problem but not the tranny problems i am so confused .i was on my way to see my boys play in specail olympics state when it gave out
Old May 17, 2014 | 02:43 PM
master tech
If the engine isn't running correctly that will effect the transmission. I would have the engine checked for a misfire before taking the transmission apart.
Old May 17, 2014 | 02:48 PM
starrbright40
Default tranny sliping
thank you i will do that first .but have to wait god has not dropped some money in hand .i have two disabled children
