2wd to 4x4 Conversion
Old May 18, 2014 | 07:31 PM
DJeXeCute's Avatar
DJeXeCute
Default 2wd to 4x4 Conversion
I just came into ownership of a 4x4 trans and transfer case off my friends recently totaled 98 dodge ram. I also have a front hp dana 44 laying around. What I was wondering is I know there is allot of fab work involved with doing a 2x4 to 4x4 conversion when using stock links but what If I did it with Long arms? Then its just a bracket that bolts in place of the cross member. I would just need 4x4 linkage, The Coil buckets and shock tabs right?
I'm looking into doing this on my 1998 Dodge ram 1500 single cab short bed 53k orig miles
Old May 19, 2014 | 12:33 AM
Wombat Ranger's Avatar
Wombat Ranger
Easiest way to do it will be with leaf springs.
Far as building your own custom multi link suspension you are on the wrong forum. Try Pirate4x4.com. Read, do not ask your question there. If you read a few threads you will understand why I say that.
Old May 19, 2014 | 12:49 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
^^ hahah Wombat.
DJ -- Yes, you have the general concept down. Is the hp44 you have driver side drop? Now get started!
Old May 19, 2014 | 11:42 AM
DJeXeCute's Avatar
DJeXeCute
I was looking into the bds 5" lift with pre fabbed multi link new leafs coils etc.
It's $1,600 so I'm going to be waiting awhile on this I want to have the trans and t-case gone through and rebuilt before anything first just to be on the safe side.
http://www.offroadwarehouse.com/prod...roductID/54680
Old May 19, 2014 | 05:24 PM
ryan0714's Avatar
ryan0714
be much better off just piecing together your own money wise. just sayin... 2500 coils will net you 2-3" and then throw a spacer on top of them for your 5" then all you gotta worry about is the back, either do a block or buy lifted leafs.
Old May 19, 2014 | 06:34 PM
If only it were that easy. Beyond about 3" of lift, gotta deal with pitman arm, track bar, and control arms, so that things line up where they should, and you can actually do an alignment.
Old May 20, 2014 | 01:20 PM
ryan0714's Avatar
ryan0714
yea true that I forgot about being above 3". but still it would be cheaper to buy them all indidually than to pay 1600
Old May 20, 2014 | 04:42 PM
Wombat Ranger
Guys he has a ford axle. Not a POS 2nd gen LP CAD unit bearing 44 haha.
Old May 20, 2014 | 07:44 PM
DJeXeCute's Avatar
DJeXeCute
Not sure but It is a king pin style axle
Old May 20, 2014 | 08:04 PM
Wombat Ranger
If it is a high pinion full width D44 it's a Ford, I cannot think of any other application for a HP44 in a truck. Hmm kingpins does it have open or closed knuckles?
