Starting
Old May 23, 2014 | 10:10 PM
jayrak's Avatar
jayrak
Default Starting
I have a 2000 Ram 3500 with a Cummins and a 6 speed, it has quit starting with the key switch, if I jump the solenoid terminal to the battery the starter runs and starts the engine. What should I look for to correct this issue?
Thanking you all in advance for your advice,
David
Old May 23, 2014 | 10:54 PM
i4got68's Avatar
i4got68
I'd try replacing the solenoid since you were able.to.start it by jumping that
Old May 24, 2014 | 11:17 AM
Go for the starter relay in the power distribution center first. Being able to short the solenoid at the starter, and have it crank the engine shows that part is actually working as it should.
Old May 24, 2014 | 04:10 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
check for power at the solenoid and work your way back to ignition switch my guess is relay
