How do I prime new oil pump.
Old Jun 1, 2014 | 09:53 AM
giulietti07's Avatar
giulietti07
Default How do I prime new oil pump.
Changing my oil pump for a high volume pump but my question is how do I prime the new pump so I will have pressure?
Old Jun 1, 2014 | 10:08 AM
The procedure is ridiculously simple..... you pour a bit of oil into the top of the pump before you install it.... that's it. I filled it up, turned it a bit (backwards, so the oil would get into the gears) added a bit more, and installed it. Pressure came up almost immediately after startup.
Old Jun 1, 2014 | 10:38 AM
giulietti07
Sweet thanks. Pour the oil into either hole?
Old Jun 1, 2014 | 10:59 AM
AtomicDog's Avatar
AtomicDog
I use this tool to turn the oil pump to pressurize the oil system when building or modifying a motor. Its handy to have and works on most MOPAR V8s:
http://chucker54.stores.yahoo.net/maoilpuprrod.html
Old Jun 1, 2014 | 12:39 PM
giulietti07
Okay so my truck is showing no oil pressure do I have to give it some time or what?
Old Jun 1, 2014 | 12:58 PM
giulietti07
Update I brought the rpms up a little the oil pressure went up but then back down
Shouldn't take more than a few seconds to build pressure......
Old Jun 1, 2014 | 12:59 PM
giulietti07
What about the rpms thing
Old Jun 1, 2014 | 01:07 PM
giulietti07
This is really starting to worry/**** me off...
