Socket
Old Jun 24, 2014 | 10:13 PM
Blue Mopar01's Avatar
Blue Mopar01
Default Socket
Does anybody know where I could get a socket for these studs? I lost mine and I need to take off my rims to do brakes. I think the rims are either American Racing or Cragar. They were on the truck when I bought it. Any help is appreciated
Old Jun 24, 2014 | 10:31 PM
p38251's Avatar
p38251
Your local tire shop should be able to get one
Old Jun 24, 2014 | 11:05 PM
AtomicDog's Avatar
AtomicDog
Any decent auto repair shop should have a wheel lock removal set that should take these special lug nuts off. They would likely be damaged during removal. Is there any issue with replacing the lug nuts with better looking, non-rusted nuts? If not, pick up a new set of lugs nuts and search out a auto repair shop that has the tools to remove the old ones.
Old Jun 25, 2014 | 08:02 PM
Blue Mopar01
I'm playing with getting new ones but I'm not sure where to look. Anybody know where I could get a whole set?...If i get them off, for now I'll repaint them black
Old Jun 25, 2014 | 08:20 PM
AtomicDog's Avatar
AtomicDog
It does not look like any special lug nut is needed to bolt those wheels on. I suspect that the standard lug nut to fit that lug stud thread pitch with a 60 degree conical seat taper will work fine. For example, these should fit, once you get those old lug nuts off.
http://www.autopartswarehouse.com/sk...GOR41187B.html
Since you have some room to work, I'd try using a pair of Vice Grips and a hammer to remove your existing lug nuts, one by one.
Old Jun 26, 2014 | 09:55 AM
But don't completely remove them till you have them ALL loosened up a turn. Otherwise, that last one is gonna be a real drag to get loose.
Get them all to turn a quarter, to half a turn, THEN take them off.
Old Jun 27, 2014 | 08:24 PM
Blue Mopar01
I found a socket that may work. Cornwell tools has a dodge wheel stud/nut socket. I have it and it feels like it'll work. I need a 1/2" extension to use it though. Hopefully this will do the trick. Thanks guys, btw has anybody had any issues changing out the rotors and brake pads up front?
Old Jun 28, 2014 | 11:49 AM
Disc brakes are easy on the half tons.... If you are changing pads/rotors, it's about a 30 minute job.
Old Jun 28, 2014 | 01:28 PM
Blue Mopar01
Oh, sweet. I never did brakes before on my truck so I was wondering. Maybe I won't have to have someone else do them then. Heyyou, is there a better place to get rotors and pads besides rock auto?
Old Jun 28, 2014 | 01:51 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
those are gorilla brand lock nuts order a key for them
