Best brakes since I've owned this truck.
Old Jun 30, 2014 | 12:08 PM
If the problem is excessive travel, try adjusting the rears. If they are spongy, bleed the brakes again.
Old Jun 30, 2014 | 12:19 PM
Ham Bone's Avatar
Ham Bone
I have the 8800 pounds calipers. Dual piston. And the stock smaller 1500 master cylinder. The 2500 master cylinder will not fit in the brake booster.
I have rear discs also. But I have no pedal travel where nothing happens. I have a really stiff, really great pedal.
Old Jun 30, 2014 | 02:12 PM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Ok, thanks Ham! Good to know someone else has 8800lb calipers that work.
Hey You, Thanks, I'll try adjusting the rears.
Old Jul 3, 2014 | 10:45 PM
charlie1935's Avatar
charlie1935
Originally Posted by 1997JollyGreenGiant
So you went with the 7500lb calipers? Why not the 8800lb calipers?
I was reading here that the 8800lb calipers may cause excessive pedal drop while driving https://dodgeforum.com/forum/2nd-gen...upgrade-9.html
Is that correct?
I was under the impression that the HD calipers were not a bolt on.
Old Jul 5, 2014 | 11:33 AM
1997JollyGreenGiant
They bolted right onto my truck.
Old Jul 5, 2014 | 11:42 AM
Single or dual piston? What year calipers?
Old Jul 5, 2014 | 05:00 PM
1997JollyGreenGiant
Single piston, 1997 year calipers. It's these right here http://www.napaonline.com/Catalog/Ca...899_0248587881
Old Jul 5, 2014 | 06:14 PM
Ah, yep. Same ones I have on my truck. Think they went to the dual piston in 98 or some such.
Old Jul 5, 2014 | 09:08 PM
AtomicDog's Avatar
AtomicDog
Interesting. Do the '98-up dual piston calipers bolt right on to the earlier model 2nd gen 4WD trucks? Do they really make a big difference in braking performance?
Old Jul 5, 2014 | 10:24 PM
1997JollyGreenGiant
No, I don't think the dual pistons bolt right up. They do, to my knowledge, make a big difference in stopping power.
