Bad Shifting
Old Jun 29, 2014 | 04:27 PM
98dodge2500.'s Avatar
98dodge2500.
Default Bad Shifting
My truck is a diesel and my shifting is very bad between 45mph - 50mph. All of my fluids are great and change and new. It will shift high then low then just go back and forth. What's wrong?
Old Jun 29, 2014 | 06:42 PM
archemedes74's Avatar
archemedes74
do the diesels have a lock-up converter? Lock-up normally would occur between 45 and 50, could be not going into lock-up, or not holding? Do you have any codes?
Old Jun 29, 2014 | 08:36 PM
If it were gas, I would say throttle position sensor.....
Old Jun 29, 2014 | 09:24 PM
98dodge2500.
I don't have any codes.
Old Jun 29, 2014 | 09:32 PM
Test the tps. It may be doing the same thing the gas trucks do....
Old Jun 29, 2014 | 10:14 PM
thzpcs's Avatar
thzpcs
Wouldn't the TPS be basically the same if it were gas/diesel?
Old Jun 30, 2014 | 08:16 AM
It does the same job, so, I am going to guess that it could also cause the same problems.
