intake manifold removal help
Old Jul 7, 2014 | 01:50 PM
Originally Posted by Arde
Another thing about head bolts, I heard long ago not to use a wire wheel to clean the threads. Have often wondered how many guys do that, and if they actually have any problems because of it.
I'm not really sure what the issue would be there.... unless they come with some coating on them? I have wire wheeled head bolts on many occasions, and never had a comeback.
Old Jul 7, 2014 | 05:21 PM
archemedes74's Avatar
archemedes74
I was always told not to do it because the wheel will grab the bolt and fling it across the shop, the tolerance of standard bolts isn't close enough for the wire wheel to remove enough material to make a difference
Old Jul 7, 2014 | 06:08 PM
AtomicDog's Avatar
AtomicDog
So long as one doesn't go crazy with using a wire wheel on the head bolt, there are no issues with the practice. I've done it, along with running a die across the threads to ensure they are clean and have had no issue with either practice. I also run a tap into the block's head bolt threads to ensure they are clean, too.
Old Jul 7, 2014 | 06:32 PM
That's actually suggested practice when re-using head bolts. (and running the tap down the bolt holes in the block regardless.) Gives you more accurate torque when bolting things down.
Old Jul 7, 2014 | 08:36 PM
DodgeFanMP's Avatar
DodgeFanMP
Default Stupid question...do the later 2nd gens not have EGR valves?
Originally Posted by drtydn
yup it was the egr tube... i couldent get a wrench behind there so i too my chances with taking the two bolts from the exhaust manifold... to my suprise they came right out... in fact to my suprise i havent broken a bolt yet and im doing head gaskets... got one head off doing the other tomorrow... i know for a fact im putting anti seize on everything before reassembly
I just replaced the plenum and intake manifold gaskets on my 2001 5.9L and had no EGR tube connected to the manifold. I didn't realize other 2nd gen Rams had an EGR valve.
Old Jul 7, 2014 | 08:46 PM
94-95 had egr. 96 and up did not.
Old Jul 7, 2014 | 08:49 PM
DodgeFanMP's Avatar
DodgeFanMP
Default Cool. Thanks!
I learn something new every day :-)
Old Jul 8, 2014 | 07:41 AM
RDuck's Avatar
RDuck
Im told to toss the factory head bolts and buy new ones.
Because they stretch when torqued and dont come back after.
Factory bolts reused just stretch again. Actually making them more prone to stripping or stretching under pressure or breaking.
I know. We've reused them for years and still will. I personally have never bought new and never had an issue.
Just saying. I myself may switch to ARP studs if I need to pull my heads off for any reason. Well, I'd at least think about it.
Plus I'd shave the heads for a bit more compression.
Port, polish, big valves maybe if doable, better springs.
I mean, while their off.
Cost although is a factor.
Old Jul 8, 2014 | 09:34 AM
Investing that kind of money into the stock heads is a waste. The castings are already too thin, so, shaving them would only exacerbate those issues. If you want to improve your heads, replace them. You can get a pair of Iron Ram EQ heads (2.02 intake valves) for under 1000 bucks shipped, and they are MUCH better castings than stock.
Old Jul 8, 2014 | 11:40 AM
RDuck's Avatar
RDuck
See. If you have to remove them and you can afford it, get those.
I hate doing things twice when you know you want them.
