Shorty header Help Please
Old Jul 6, 2014 | 04:51 PM
sam3293's Avatar
sam3293
Default Shorty header Help Please
I am installing my pacesetter shorty headers today and the side the goes to the engine has 4bolts and 2 studs but the new headers require shorter bolts and studs where can I get these?
Thanks
Old Jul 6, 2014 | 05:12 PM
AtomicDog's Avatar
AtomicDog
Pacesetter headers come with header bolts. Did you purchase these new or pick up a used set? If used, you can contact Pacesetter and ask them to send you out a set of bolts for their headers. They are slightly longer than the header bolts readily available at local parts stores. They are also 5/16" threads.
Old Jul 6, 2014 | 05:38 PM
sam3293's Avatar
sam3293
They are new but never came with screws
Old Jul 6, 2014 | 05:41 PM
Spillage's Avatar
Spillage
Contact Pacesetter...
My LT's came with hardware.
Old Jul 6, 2014 | 07:05 PM
AtomicDog's Avatar
AtomicDog
I bought a used set of Pacesetter headers some time ago via my local craigslist and had to order the header bolts from them.
Old Jul 6, 2014 | 08:28 PM
sam3293's Avatar
sam3293
Thanks for the info I'll call them tomorrow. Hopefully the temporary bolts I put in stay tight the test went well so far.
Old Jul 6, 2014 | 09:34 PM
Z.rawk95's Avatar
Z.rawk95
I just went to napa and picked up some grade 8 bolts and threw them in there when I did mine.
Old Jul 7, 2014 | 07:58 AM
sam3293's Avatar
sam3293
I went to lowes and bought the grade 8 bolts to just hold the header but the outer tubes inner bolt won't tighten all the way since the bolt head touches the manifold
Old Jul 7, 2014 | 08:07 AM
AtomicDog's Avatar
AtomicDog
I had the same issue. I used grade 8 studs in some places where nut clearance allowed and Pacesetter header bolts in tight clearance areas.
