loud squeak/squeal from front of motor
Old Jul 6, 2014 | 07:09 PM
1997dodge1500's Avatar
1997dodge1500
Default loud squeak/squeal from front of motor
I have a 1997 dodge ram 1500 that is making a loud squeak/squealing noise from the front of the motor. The noise only happens when the truck has been up to temperature for about 2 minutes. It will NOT make the noise above 2500 rpm or when under load. I have replaced the serp. belt, fan clutch, water pump and alternator because it made a slight squeak. I have also checked the idler pulley and belt tensioner which both felt fine. The noise does not change when you add pressure to the belt, use the a/c, or turn the wheels. I am at a loss and could really use some help. Thanks.
Old Jul 6, 2014 | 07:40 PM
Take the belt off, and spin things by hand. See if anything (that's left...) feels off.
What brand belt?
How is the tensioner spring? Does it give full travel? Nice and strong?
Welcome to DF!
Old Jul 7, 2014 | 09:05 PM
DodgeFanMP's Avatar
DodgeFanMP
Default I am no expert, but have you installed an after market plenum plate?
I only ask because I just had a mystery squeal that sounded like this:
http://youtu.be/4Jf25rq-T9E
It turned out to be a leaky plenum gasket. Just a thought if you can't find the source of the noise elsewhere. Good luck!
Old Jul 11, 2014 | 01:31 PM
1997dodge1500
What brand belt?
Welcome to DF!
i took the belt off and felt everything but still came up with nothing. i have been told it could be the plenum plate but that is not the noise i am hearing.
Old Jul 11, 2014 | 01:47 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
It could be the belt tensioner bearing. The tensioner is supposed to be replaced ~75K miles, although I know few people who've done so.
