death wobble
Old Jul 10, 2014 | 11:35 PM
  #21
bigred95's Avatar
bigred95
Oh, sweet. I'll give that a shot tomorrow whil. I'm under the truck, cause literally on my way up to the shop my abs and brake light stayed on and the speedo started acting up, so I'm replacing the sensor on the diff tomorrow, unless you think it could be something else
Old Jul 10, 2014 | 11:37 PM
  #22
bigred95's Avatar
bigred95
Also just went to post pictures and can't figure out how to post them...
Old Jul 11, 2014 | 12:11 AM
  #23
djbucky3's Avatar
djbucky3
post them to an external photo hosting site, such as photobucket.com and then put the links to them on here. Its much easier.
Old Jul 11, 2014 | 12:14 PM
  #24
bigred95's Avatar
bigred95
Size:  70.9 KBtook off the pin and castle nut at frame end, used 7/8 with a half inch breaker bar. You could keep the nut on to prevent the bar from dropping when you separate the ball joint, but i just took it off
next i loosened the bolt at the axle end of the bar, once again half inch breaker bar but 18mm socket.
to separate the ball joint from the frame i just used a pickle fork and a BFH (mine was a sledge with a weight on it lol) once the pickle fork can't take it out any more just wiggle it around, the ball joint should come out
here is the old track bar and new one, my old bar needed a little persuasion with the sledge to come out on the axle end
I put the axle end in first, didn't have room to put a come along to pull to the passenger side. This is a hole on the frame near the bumper
just another picture of where the come along comes out. You will need to do this, unless you're on a completely flat surface
this was how i put my ball joint in the frame. Wasn't a big fan of hitting it in with the sledge, then torqued the axle bolt to 130 ft/lbs and the ball joint nut to 80ft/lbs. It's 70 stock but the moog bar calls for it tighter
Attached Thumbnails death wobble-20140710_134538_zpsl6fklaoo.jpg   death wobble-20140710_134337_zpsk7kq9mr6.jpg   death wobble-20140710_144957_zpswsmb7bwa.jpg   death wobble-20140710_144942_zpsjwbr6lha.jpg   death wobble-20140710_143744_zpsnf0zohlt.jpg
Old Jul 11, 2014 | 12:34 PM
  #25
To get mind to line up, I just had a friend lean on the truck a bit... worked great.
Old Jul 11, 2014 | 05:03 PM
  #26
bigred95's Avatar
bigred95
Yeah that would work too, but i was on such an uneven surface it didn't work too well with someone pushing. I just had to use a come along
Old Aug 10, 2014 | 04:01 AM
  #27
Moparadict's Avatar
Moparadict
I have had lose steering, and wandering from a worn track Barr. But only once experienced a death wobble. It was a 98 3500 with the dually. I checked everything several times, but last I pulled both steering stabilizers down (shocks) and found the upper one weak. Replaced it, and made it years without the death wobble ever showing again. Almost wore it all out finding every bump, and hole to test it after. All good.
Just something to look at. It may help
