ram 1500 grinds in first,second and third gear
Old Jul 13, 2014 | 12:35 PM
davesredneckwine's Avatar
davesredneckwine
also, if i swap the trans/tcase, should i replase the output shaft snap ring? ive been told that it is a common problem. what else should i do to the trans/tcase to prevent issues in the near future? it has 112k miles on it, thank you for your help
Old Jul 13, 2014 | 12:59 PM
Should bolt right in then.
Old Jul 18, 2014 | 08:09 PM
davesredneckwine
are the 231 and 241 transfer cases interchangable?
Old Jul 18, 2014 | 08:24 PM
Arde's Avatar
Arde
Don't just replace the snap ring, replace it with a Transfer Case Saver. It completely eliminates the trouble prone snap ring.
Old Jul 18, 2014 | 10:16 PM
Kinda. There ARE some differences. If that is the route you choose to go, get one from a donor truck same body style/bed length as yours, and grab the driveshafts as well. You can get hybrid u-joints to go from the larger shafts, to the half ton axles.
Bear in mind, 241s out of a diesel, or v-10, will have a different input gear, than the V-8 versions. (there were no v-6 3/4 ton 4x4's.)
Old Jul 19, 2014 | 02:19 PM
davesredneckwine
does it have to be off of a manual trans or does that matter? and thanks for all the help
Old Jul 20, 2014 | 10:07 AM
I think the input gear is longer on the manual..... I think.... It *might* work from an auto... not sure on that one.
Old Jul 22, 2014 | 11:11 PM
davesredneckwine
so I pulled the transfeer case and replaced it with a 231d, got it all back together fine and it still makes the same noises, in first, second, and third gear. also, the tcase that i pulled has a place for a three wire connector and the new one doesnt, can i switch rear output cases? and the speedo doesnt work, it dies when i brake to a stop, and the tcase shift pattern is different. any ideas? the old tcase is pretty wasted, the seals are leaking badly and show wear
Old Jul 23, 2014 | 10:19 AM
Trans problem? You have the NV3500??
Old Jul 23, 2014 | 12:25 PM
davesredneckwine
yes i have the nv3500
