Pushrod Question
Old 10-05-2014, 11:12 AM
renardk764's Avatar
renardk764
renardk764 is offline
Therein lies the problem. With the rocker and adjustable pushrod installed, the roller tip of the rocker sits on the edge of the valve stem on the intake side. Extending the adjustable pushrod moves the roller to towards the center of the valve stem, where it should be. But it compresses the valve, resulting in the valve never being completely closed. This link shows the installation process by another manufacturer of a similar product. I've sent Hughes an email asking for clarification. It'll be interesting to see what they say.
How to install Yella Terra High Performance Rolle…:
Ken
  #32
Old 10-05-2014, 11:28 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,189 Likes on 2,942 Posts
IF the rockers are adjustable, move them up just a bit, then run your pushrod tool out a little longer, that should do it.
  #33
Old 10-05-2014, 05:27 PM
Adobedude's Avatar
Adobedude
Adobedude is offline
What are you doing....?
Back away from the LS1 video, it's NOT how you install your Hughes Rockers, they are not similar in their installation at all, the LS1 rockers in the video are non adjustable rockers, your Hughes Rockers are adjustable.
Install the adj push rod, start with the old length, make a make on the valve stem, install the rocker and adjust the preload on the lifter, rotate the engine by hand two revolutions, pull the rocker and check the tip of the valve stem, if the mark is too close to the intake side of the motor the push rod is too short...if the mark is closer to the exhaust side of the motor it's too long, pull the push rod and correct the length, and do the above until the tip of the roller rides on the center of the valve stem.
You torque the bolts holding the rocker mounting shafts down to 30lbs, but the rockers themselves are adjusted like normal rockers, don't torque those down...adjust to 1.5 to two turns past zero lash.
Read the Hughes instructions, it's all there.
  #34
Old 10-05-2014, 05:47 PM
Adobedude's Avatar
Adobedude
Originally Posted by renardk764
They are. The picture is without pushrods installed.
Well of course they are going to look like that without pushrods....LOL
Nothing is holding the *** end up.
  #35
Old 02-01-2016, 01:39 PM
ramhuskyhauler's Avatar
ramhuskyhauler
ramhuskyhauler is offline
www.stores.hi-potek.com
offers push rods in .025 increments.
Most companies offer in .050 increments.
So when you need .030-.040 preload into the lifter these push rods will get you where you need to be.
I purchased an adjustable push rod from Hughes Engines to figure out my proper rocker arm geometry.
Quick Reply: Pushrod Question
