engine year
Old Aug 6, 2014 | 09:48 PM
cg1999's Avatar
cg1999
Default engine year
Can anyone tell me the year from the casting number on the block of a 90s or2000s model dodge ram the number is a s or a 5 3020006.360
Old Aug 6, 2014 | 10:41 PM
I believe there should be a date code cast into the block as well....
Old Aug 7, 2014 | 10:11 PM
cg1999's Avatar
cg1999
Do you know where and what those number mean
Old Aug 8, 2014 | 11:40 AM
Usually the casting date is on the drivers side, just above the freeze plugs. it is in standard format, mm.dd.yy
The casting code is basically just a part number. I do believe those are the same for all blocks of the same displacement. (maybe minor changes over its production life.
