wheel bearing hub assembly want spin once it is torqued to the 185lbs
Old Aug 7, 2014 | 05:50 AM
signsnow08's Avatar
signsnow08
Default wheel bearing hub assembly want spin once it is torqued to the 185lbs
The problem im having is that once i torque the nut to 185lbs the hub will not spin. the truck is a 2001 1500 2 wheel drive and the hub has the sealed bearings it it already.I installed a new hub assembly and new nut but once i tighten the nut to 185lbs it want spin,at this point i,m lost. I've never seen anything like this so any help would be great.
Old Aug 7, 2014 | 07:28 AM
AtomicDog's Avatar
AtomicDog
Take a look at this thread - sounds like 185 ft/lb may be too much torque for that style bearing assembly:
https://dodgeforum.com/forum/2nd-gen...-like-mad.html
Old Aug 7, 2014 | 11:41 AM
signsnow08's Avatar
signsnow08
I read the thread but i think his has the old type bearing with the races and the old cotter key style. Mine has the newer type bearings, I think its called a unit bearing. it looks as tho it has 2 seal type bearing inside the hub. the nut that it says to replace has like teflone in it. If i tighten down slowly i can get 98% of the up and down motion out with out it seizing up but if i torque it to the 185lbs that it calls for it want turn. at this poi nt i wounder if i have a bad NEW hub assembly.
Old Aug 7, 2014 | 12:22 PM
TejasMtnBiker's Avatar
TejasMtnBiker
if these are hub style, then no matter what torque you put on it will keep the bearing from spinning... have you put the wheel on it yet and tried to rotate it by hand?
Old Aug 7, 2014 | 12:37 PM
Ham Bone's Avatar
Ham Bone
Post a picture.
If you have old school style you just do it by hand feel.
If you have a unit bearing you have to torque it to spec or it will blow up in short order. Almost Sounds like your bearing is bad.
Old Aug 7, 2014 | 12:52 PM
signsnow08's Avatar
signsnow08
havent put the tire on yet because the hub was tight. Im used to the old style, u tighten them to there just right and stick the cotter key in it. im 99%sure its the unit bearing. it loooks nothing like the old style with with bearing and race.as of right now its torqued at 185lbs and want spin. going to stick the tire on and see if it spins.
Old Aug 7, 2014 | 12:55 PM
TejasMtnBiker
these hubs are like my 03 model but mine turned freely before & after installation so you could have a tightly pressed bearing and may need to swap it... yeah the old style was easier never had issues with those on my 85 ram
Old Aug 7, 2014 | 01:13 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
You posted your question in another thread and it was answered
https://dodgeforum.com/forum/3187400-post19.html
Old Aug 7, 2014 | 02:01 PM
TejasMtnBiker
not really answered... but The 3 hub bearing bolts should be torqued to 122 ft/lbs if you really feel the need to do that they are quite large it would take massive vibration to make them loose
Old Aug 7, 2014 | 02:03 PM
signsnow08's Avatar
signsnow08
trying to attach a photo but having trouble.
Attached Thumbnails wheel bearing hub assembly want spin once it is torqued to the 185lbs-will.jpg
