front axle not centered?
Old Oct 5, 2014 | 05:45 PM
  #41
Johnn123's Avatar
Johnn123
Id check all the axle u joints and drive shaft (both) u joints.
Old Oct 5, 2014 | 06:09 PM
  #42
Juvenator93's Avatar
Juvenator93
I'll keep looking around and checking for it
Old Oct 5, 2014 | 07:27 PM
  #43
Juvenator93
I've moved everything and can't seem to find it. Only thing that moves are the drag link and the tie rod rotate and the pitman arm has a little up and down movement. Could the pitman arm make a clunk over a speed bump?
Old Oct 6, 2014 | 07:06 PM
  #44
Do anything with the shocks? Them fellers need to be TIGHT to be quiet.
Old Oct 6, 2014 | 11:12 PM
  #45
Johnn123's Avatar
Johnn123
Theres another good one to look for.
Got someone that can move the steering while you're under it, see whatsgoin on?
Old Oct 7, 2014 | 11:06 AM
  #46
Juvenator93
Shocks are tight and to torque and I got my brother to turn the wheel while I was under there and the pitmam arm shifts up and then back down when turned. Also if I move it up and down the sound is real similar to what I hear over bumps. Think I found the source. How do I tell if it's the pitmam arm or the gear box?
Old Oct 7, 2014 | 02:08 PM
  #47
Which one is actually moving?
Old Oct 7, 2014 | 05:55 PM
  #48
Juvenator93
I'll post a video when I get home. I think it's the gearbox that moves up and down, causing the pitman arm to move with it
Old Oct 8, 2014 | 10:18 AM
  #49
Wh1t3NuKle's Avatar
Wh1t3NuKle
Old Oct 11, 2014 | 01:28 PM
  #50
Juvenator93
Sorry for taking so long guys. I tried recording the pitman arm back and fourth with my brother turning the wheel but it doesn't really look like it's moving... I also recorded me moving the drag link up and down so the clunk noise is audible but you can't really see the movement either (I can still post them if it helps). I think it's the pitman arm itself though. It's $30 at my local O'Reilly. How hard is a pitman arm to change?
