1st start of engine in 3 years
Old Oct 9, 2014 | 06:23 AM
Canyon Man's Avatar
Canyon Man
Default 1st start of engine in 3 years
Hello guys,
Within the next few weeks I plan on starting up my truck that has been sitting for about 3-4 years. It's been a project on the back burner needing a tranny rebuild and now I would like to get back into it. 1996 Dodge Ram 1500 4x4 extended cab. So is there anything I need to do to the engine before I crank it over for the first time?
Old Oct 9, 2014 | 07:56 AM
Fresh gas, change the oil, I would be tempted to pull the spark plugs, and give each cylinder a squirt of oil as well......
Don't be surprised if it doesn't want to start.
Old Oct 9, 2014 | 09:26 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
^Yeah, maybe just turn engine over by hand first at the crank pulley. eeek
Pull valve covers to toss some oil on directly.
I'm curious how it goes!!
Old Oct 9, 2014 | 01:41 PM
Ham Bone's Avatar
Ham Bone
10 bucks it fires right up
Old Oct 9, 2014 | 02:57 PM
AtomicDog's Avatar
AtomicDog
I'll take that bet, too. As long as you have a good strong battery and the battery connections are clean and tight, the motor is full of oil and there's fuel in the tank, I suspect it will fire right up, as long as the truck was in a decent state of tune prior to it running last.
Old Oct 9, 2014 | 03:17 PM
stewie01's Avatar
stewie01
Only one way to prove it, YouTube.
Old Oct 9, 2014 | 07:48 PM
Canyon Man's Avatar
Canyon Man
LOL, Will do. It will be a week or so yet but when I put it in the garage the motor ran great
Old Oct 9, 2014 | 08:07 PM
Canyon Man's Avatar
Canyon Man
I was gonna change plugs,wires,cap and rotor. Any brand recommendations or ones I should stay away from?
Old Oct 9, 2014 | 08:35 PM
stewie01's Avatar
stewie01
Generally these trucks like plain ole copper plugs. I can't remember if I did a new cap/rotor/plugs when I did my plenum repair but if I did it was AutoZone brand and they haven't failed me yet
Old Oct 9, 2014 | 09:05 PM
Adobedude's Avatar
Adobedude
Priming the motor in these things is a PIA, I'd pull the fuel pump relay, or coil wire and let it spin to lubricate the motor and build oil pressure.
