Truck sounds like it's under a have load
Old Oct 12, 2014 | 03:02 AM
intrepid31's Avatar
intrepid31
Default Truck sounds like it's under a have load
I have A 99 Ram 1500 4x4 with 5.9L V8 Magnum that the water pump went out on. In the process of repairing the truck I had to take an air hammer/chisel to the fan clutch nut. after looking at the nut I no longer felt that I could trust it's integrity, so I bought a new fan clutch and installed it. Now the truck sounds like it's under a heavy load (as if I was starting up a hill from a dead stop pulling a trailer load down with 2 yards of gravel). I have also notice that the RPMs seem to be higher than normal. The RPMs reach 3k just getting up to 35 mph. (driving normally)
I'm wondering if I might have gotten a bad fan clutch. Just need a few other opinions here.
Old Oct 12, 2014 | 10:09 AM
Sounds like TV cable out of adjustment......
Old Oct 12, 2014 | 03:22 PM
intrepid31's Avatar
intrepid31
TV cable ? please clarify your meaning.
Old Oct 12, 2014 | 08:32 PM
SilverSS's Avatar
SilverSS
Throttle Valve cable. Here's a link with instructions on how to check/adjust it. Scroll down until you see it.
http://api.viglink.com/api/click?for...2520Tricks.pdf
Didn't forget to release the parking brake did ya? When the engine is cold and off try to spin by hand. Should spin but have some resistance. If it spins easily or not at all it's bad.
Old Oct 13, 2014 | 12:54 AM
Twmays's Avatar
Twmays
You didn't happen to get a "heavy duty" fan clutch, did you?
I replaced mine with a heavy duty clutch following a plenum repair, and noticed that it sounded like a jet engine spooling up when I first turned it over. Every so often, I would get the same roar at startup that would last until the engine got warm. Figured it was just the oil or whatever in the clutch spinning until it realized it was warm but not hot and didn't need to turn the fan.
Recently went to an efan setup and haven't looked back.
Otherwise, fan clutch should have absolutely nothing to do with shift points. I'd follow HeyYou's advice and check the throttle valve cable. It's on the throttle body, passenger side, and runs towards the firewall on its way to the tranny.
Old Oct 13, 2014 | 12:58 AM
Adobedude's Avatar
Adobedude
Sounds like clutch fan to me,
Old Oct 13, 2014 | 08:20 AM
Ham Bone's Avatar
Ham Bone
Who needs a fan anyway? Just take it off! Lol
Old Oct 13, 2014 | 03:26 PM
intrepid31's Avatar
intrepid31
After looking at the receipt and the box and match up the part numbers to napa's website it looks like what I got is a Severe Duty Fan Clutch. The other ones list are heavy duty or Severe Duty. Also looked at the websites for other part houses in the area and these are the only two options list, no one seem to have just a standard one listed.
Old Oct 13, 2014 | 03:38 PM
intrepid31's Avatar
intrepid31
Parking brake was not on, and the fan does have some resistance when spinning by hand. Still have to check the TV cable.
Old Oct 13, 2014 | 07:58 PM
intrepid31's Avatar
intrepid31
Took Fan clutch off and returned it to napa. Went to a different napa got a different fan clutch under the same part number. Installed new fan clutch truck is now fixed and running like normal.
