Hello 95 Ram Michigan
Old Nov 18, 2015 | 09:16 AM
Hit it with some chems, put a punch/drift on it, and tap it a few times. (you just want to get it to vibrate a bit, you don't want to damage anything, so, don't hit it too hard.) Use the appropriate size socket on it, not a screwdriver...... See if it wants to break loose.
Worst case, you will have to pull the distributor. (pay attention to where the rotor is pointing. It's important.)
Old Nov 18, 2015 | 09:27 AM
tsvallette's Avatar
tsvallette
Yah that is exactly what I was thinking and what I really don't want to do so I will try two more possibility before I pull it out. I am not exactly sure what size socket to you. I have tried 6mm and that seems too small, 6.5mm seems just right but wont grab (skips), I cant get 7mm on there due to clearance issues the bolt and the side of the distributor cap has. I'm thinking of getting my dremmel in there and put in a slot and use a flat head screwdriver to unscrew it. Then if all else fails I'll have to drill/grind off the head of the bolt/screw pull the cap off and hope that there is enough of the bolt left to grab it with some vicegrips.
Old Nov 18, 2015 | 10:59 AM
Try some standard sizes..... I don't recall what size it actually is....
