2001 Dodge Ram 2500 no hazards or turn signals
Hi,
New to this site and need help on this one. 2001 Ram 2500.Replaced multi function switch,hazard relay,checked all the fuse and bulbs,wiring.I have running lights and brake lights but no turn signals or hazards.could the issue be in the fuse panel itself (inside truck) as my power windows also do not work (they did before the lighting issue)Looks like a pain in the butt to remove this panel inside,but has anyone come across this issue ? Thanks I did disconnect the rear t connects and plugged them back into the factory harness in case that was an issue,but still have this problem. Again thanks for any input, Bob
As I had previously mentioned I had replaced the relay,checked all the fuses. I did every simple check I could think of besides changing the fuse panel.Also disconnected the main wiring harness and cleaned the terminals with electronic cleaner.My windows do operate now as one of the plug ins were loose but still no blinkers or hazards.
Did you ever find the problem? I have the same issue with my 2001 Dodge Ram 3500 Cummins 5 speed 4x4. Just replaced my multi-function switch and.... still nothing. Sometimes they start working for a few mins/hours, but then they quit again.
I have this 01 dodge 2500 24v i have no turn signals and now my hazzards just stay solid dont do anything and my turn signal dont even work changed the relay and the turn signal switch 2 times and still same any help would be great iv check everything and nothing seems to be wrong
