Most Critical o2 Sensor to Change?
Old Oct 20, 2014 | 12:07 PM
jmhd1989's Avatar
jmhd1989
Default Most Critical o2 Sensor to Change?
i was thinking of just replacing my o2 sensors since i am replacing all other sensors on the truck, IAC,TPS,MAP, CPS. Is there One sensor that does more work than the other as in truck efficiency? i don't care about ones that are just for emissions. Also how many are there if i were just do them all?
Old Oct 20, 2014 | 12:14 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Change all at the same time. Maintenance is cheaper in the long run when done properly.
Old Oct 20, 2014 | 02:25 PM
jmhd1989's Avatar
jmhd1989
i was leaning towards that route, how many do the 5.9's have total?
Old Oct 20, 2014 | 03:30 PM
Federal emissions have 2. California emissions have 4. I think.
Old Oct 20, 2014 | 05:59 PM
jmhd1989's Avatar
jmhd1989
figures, i hate CA
Old Oct 23, 2014 | 07:18 PM
jmhd1989's Avatar
jmhd1989
so i went under adn i do have four but i dont have a post cat one.... of the left manifold theres one the a collector and another same on the right side. then they combine into one exhaust no o2 then the cat than pipe and muffler. do i have three cats then? im so confused
Old Oct 23, 2014 | 08:15 PM
I think you have two "pre-cats" (in the pipes right below the manifolds?), and then the 'real' cat.
Old Oct 24, 2014 | 02:00 PM
jmhd1989's Avatar
jmhd1989
yes that must be right they look like mini cats right below each manifold. but shouldn't i still have one after the main cat/ if not how would it monitor if the main is functioning correct. i have no codes...
Old Oct 24, 2014 | 02:21 PM
That last one may not actually be a cat, either that, or Cali simply didn't care, so long as it was there.
Old Oct 24, 2014 | 10:01 PM
95' 360 Ram's Avatar
95' 360 Ram
I had a smog shop fight me back in Ca because of me not having a post cat but when I checked my stock exhaust to see if there was even wiring for it, it wasn't there. With my 95' I only had a single cat and a single O2 sensor, I know that the 2500 gassers had to cats in each manifold and another one before it headed to the muffler and had a total of 4 O2 sensors. I am assuming that 2500 exhaust systems transferred over to the 1500 as California implemented more laws in the late 90's.
