01 1500 dies won't start
Old Oct 23, 2014 | 11:49 PM
fordmanwithadodge's Avatar
fordmanwithadodge
Default 01 1500 dies won't start
Hi, I'm new here so I don't know if this is were this is sopposed to be or if this is how you do it, but here goes! OK, I have an 01 ram 1500, the other day it died on me when I came to a stop, it fired right up again when I turned the key, it died two more times coming to a stop and once when is was ideling, then I parked it when I went to start it it would not start. About the time I thought it wasn't going to start I heard a click and a hum, I turned the key and it started, this happened two more times, any ideas?
Thanks!!!
Old Oct 24, 2014 | 02:31 PM
Will it start if you give it just a bit of gas?
Old Oct 25, 2014 | 12:06 AM
fordmanwithadodge
if you mean by stepping on the gas pedal, no, the only way it will start again is if it sets awhile, and like I said I heard a click twice, then it started, not sure if it did it the other times and I didn't here it what. I couldn't tell were it came from. it's going to the shop Monday to get a wheal bearing replaced maybe they can figure it out, I was hoping someone on here might know of something and save on the repair bill.
Old Oct 25, 2014 | 03:02 AM
Ram Driver's Avatar
Ram Driver
Fuel pump ?.
Old Oct 26, 2014 | 12:00 AM
fordmanwithadodge
I don't think so, when you first turn the key you can here the fuel pump come on. Does anyone think it might be a cam sensor?
Old Oct 26, 2014 | 03:13 AM
Ram Driver's Avatar
Ram Driver
I would check the crankshaft position sensor, they can go bad with age and cause the problems your having.
Old Oct 26, 2014 | 02:09 PM
fordmanwithadodge
How would I check that, do you have to have special tools, IE scan tool?
Old Oct 26, 2014 | 03:11 PM
Ram Driver's Avatar
Ram Driver
Go to the FAQs section at the top of the page, down load the service manual for your year truck. The information you need to check things will be in there.
Old Oct 28, 2014 | 12:25 AM
fordmanwithadodge
OK, maybe I'm just stupid but I couldn't find anywhere to find a manual in the faq
Old Oct 28, 2014 | 01:12 AM
draftingmonkey's Avatar
draftingmonkey
https://dodgeforum.com/forum/2nd-gen...e-manuals.html
