exhaust
Old Dec 25, 2014 | 12:55 PM
  #51
Get two non-foulers. Drill one out all the way thru. Thread that onto the sensor, thread the second one onto that one, that put the whole thing into the bung.
Old Dec 25, 2014 | 02:45 PM
  #52
Johnn123's Avatar
Johnn123
Originally Posted by $A_Money$
Yea I got a welder an stuff I've gotta get the rear O2 sensor still but I'm goin away with the cat an gonna run true duals an put 2 mufflers an call it done but first I'm goin to put the upstream O2 sensor in an run it that way till I get my rear sensor an mufflers then off with the cat
Be sure to put a cross over in up top as well. Necessary IMO. Yup 2 mufflers and youll be good.
How is everyone doin the trick to the downstream sensor?
As HY said.
Old Dec 25, 2014 | 04:37 PM
  #53
Spillage's Avatar
Spillage
Rather than using the plug saver stack (like these generic images) ~$6/Pr
I used a spacer specifically for the job ~$12... more money, less work.
You can also get one with a ceramic insert to mimic the CAT ~$50
And there are several electronic plug-in O2 simulators, the replace the O2 all together ~65+
And some go inline with the O2 and just give the PCM the signal it is expecting, regardless of what the O2 is saying..
Old Dec 26, 2014 | 12:05 AM
  #54
$A_Money$'s Avatar
$A_Money$
I guess first ima get my O2 sensor in an see how it does an get me a rear sensor also then run it that way until I get my mufflers it's got a glass pack so I might gut the cat an run it that way I til I get the 2 mufflers an do away with the cat completely
Old Dec 27, 2014 | 11:24 PM
  #55
$A_Money$'s Avatar
$A_Money$
I gutted my cat i think I got all the stuff out of it an put my sensor in it now it runs a lil bit beter it just temporary till I get me some mufflers an get rid of the cat an make it a lil beter
