94 ram 1500 confusing vin number
Old Nov 6, 2014 | 05:35 PM
loosehead's Avatar
loosehead
Default 94 ram 1500 confusing vin number
i have a 94 ram 1500 4x4, 5.9l v8,tbi, standard tranny.vin number is 3B7JF6673RM542679.ithe truck is in mexico and i brought a ecm down from the states but ie seems to be the wrong one.according to the vin decoding shhet i got off the internet the 8 digit (7) is a 5.9 l diesel.i don`t even see an engine listed for throttle body injection just for multi port. the rest off the numbers jive and the truck was made in mexico.of course the ecm i brought down doesn`t work as it may be for a diesel.anyone have any ideas?thanks for any help
Old Nov 6, 2014 | 05:45 PM
I think your 7 is a Z, which corresponds to 5.9 gas engine. (MPFI) So far as I can tell, there was no "7" for engine designation 94-02.
Edit: Update. a vin 7 engine showed up in 98. It's the 24 valve 5.9 diesel. Your 94 did NOT have one from the factory.
Old Nov 7, 2014 | 01:37 PM
loosehead's Avatar
loosehead
thanks for the info.i recheck the vin today and it`s definatley a 7.from the spec sheet i got online that says it`s a 5.9 l ho diesel (2001),so that makes no scenes at all.so something is really screwy.i`m just trying to find out the right specs so i can get the right ecm.oh by the way it`s a 2500 not 1500.how can i tell what motor and year i have?like i said this truck was built down here in mexico so something could have been been tampered with.
Old Nov 7, 2014 | 07:28 PM
If the 8th digit is indeed a 7, then, the VIN is no good. That designation didn't show up until 98.5, with the 24 valve cummins. An engine that did not exist (except maybe on some drawing board) yet.
So, odd and strange question, is your odometer on the cluster mechanical, or electronic?
You can look on the side of the engine block, and it will tell you what displacement it is. Is it a V-8? Straight Six? V-6??? V-10?
Old Nov 9, 2014 | 08:27 AM
loosehead's Avatar
loosehead
It's define try V8 isn't there a tag on the motor somewhere?
Old Nov 9, 2014 | 08:51 AM
Nope, just what's cast into it, and that will only tell you displacement.
