deciphering fender tag to find gear ratio
Old Nov 8, 2014 | 11:51 AM
tazmaniac's Avatar
tazmaniac
Default deciphering fender tag to find gear ratio
can anyone tell me what rear gear from this or any other details..much appreciated
Old Nov 8, 2014 | 03:07 PM
What year is your truck?
Old Nov 8, 2014 | 06:15 PM
tazmaniac's Avatar
tazmaniac
1996 is the truck
there is a black strap bolted to the rearend housing
1st line: 52070214 1S, 2nd line: 3 54 605787-2
Old Nov 8, 2014 | 08:29 PM
DSA denotes limited slip.
I don't see the designation for 3.55, or 4.10 gears...... Don't know what the code for 3.92's was..... Half ton truck, right? (should put that info in your sig, and profile.)
Old Nov 8, 2014 | 11:10 PM
tazmaniac's Avatar
tazmaniac
its a 3/4 ..ya a newbie here ill get my info working
Old Nov 9, 2014 | 08:56 AM
In the FAQ/DIY section, there is a thread about getting a build sheet for your truck. It will tell you EVERYTHING that was on it from the factory, including gear ratio. There should also be a tag on one of the rear diff cover bolts, that has gear ratio on it. (of course, those are notorious for getting 'lost' when someone changes the fluid.....)
Old Nov 9, 2014 | 10:04 AM
tazmaniac's Avatar
tazmaniac
Ill send the info to that section, I did find a tag but only stated "limited slip oil" thank you for the info though
Old Nov 9, 2014 | 10:15 AM
Ham Bone's Avatar
Ham Bone
Originally Posted by tazmaniac
1996 is the truck
Pretty sure that 3.54 is for 3.55 gears.
"I think"
Old Nov 9, 2014 | 11:30 AM
tazmaniac's Avatar
tazmaniac
I entered my VIN in the decoder and you are correct..also answer my question about taller tires
Old Nov 9, 2014 | 11:52 AM
What question about taller tires?
