Hard to Steer
Old Apr 21, 2015 | 09:26 PM
  #101
issakar's Avatar
issakar
So I wonder what's up with off-the-scale pressure at idle. What's different???
That's just strange.
Where does the gauge get hooked up to test the pressure? maybe at idle the pump is not putting enough pressure out to overcome some kind of blockage, causing the pressure to shoot up (kinda like how there's a voltage spike when you cut a switch). Maybe the extra 20PSI is enough to break through that blockage?
I don't know, I'm just guessing myself at this point.
Old Apr 22, 2015 | 08:15 AM
  #102
Moparite's Avatar
Moparite
I flow at 2.0 gpm at idle, about 40psi. When I attempt to steer, the gpm drops to absolute 0, and psi goes through the roof! Off the gauge it was so high. When you rev (and don't steer) I could only get the gpm to about 2.5 and no higher.
What are the stock specs supposed to be?
Old Apr 22, 2015 | 10:26 AM
  #103
Wh1t3NuKle's Avatar
Wh1t3NuKle
It's in the FSM. For the 2000 FSM, page 19 - 4 of the Steering section.
Old Apr 22, 2015 | 04:59 PM
  #104
kgilhooley31's Avatar
kgilhooley31
I believe there's no blockage, can't guarantee it but I've changed pump box and both lines. I spoke with dura last technician, he told me to turn all the way to lock and tell him if I hear the whining/squealing, whatever you call that noise. I eat nothing. He told me my pressure valve is stuck? I find that weird seeing it's brand new....and all new fluid. I've read a review of a guy getting 3 in a row for his cummins with NO valve even in there. Completly missing. Idk if that's the case. He told me to install an inline filter to the return line. He said a grain of sand the size of a peice of sugar can make the whole system to not work.
Old Apr 30, 2015 | 08:42 AM
  #105
issakar's Avatar
issakar
Any update?
Old May 1, 2015 | 11:36 AM
  #106
kgilhooley31
Originally Posted by issakar
Any update?
I am waiting for time/money to throw an inline filter on the return side. Think I can get one for 15 bucks.
Old May 15, 2016 | 07:53 PM
  #107
beau680's Avatar
beau680
[QUOTE=kgilhooley31;3243621]I am waiting for time/money to throw an inline filter on the return side. Think I can get one for 15 bucks.[/QUO
I was wondering if you had ever found a solution to this issue?
Old May 19, 2016 | 03:28 PM
  #108
kraven's Avatar
kraven
Me too. Have a similar problem.
