Hard to Steer
Old Feb 14, 2015 | 05:37 PM
  #31
Ok, re-read thru the thread.
Just out of idle curiosity, how are you swapping the pulley over? Do you have the correct tools for removing/installing it?
Old Feb 14, 2015 | 06:22 PM
  #32
kgilhooley31's Avatar
kgilhooley31
Yeah I rented the puller/pusher kit. Nifty kit
Old Feb 14, 2015 | 06:30 PM
  #33
onegoodmason's Avatar
onegoodmason
I'm wondering if a hose is restricted . Maybe internal seal failure inside the gear from the bad pump ? Did you ever clean it out like Hey You described to see if flow was good ? Sounds like a small restriction of flow to me given 2 pumps and no go .
That's about all I can add
Old Feb 14, 2015 | 07:15 PM
  #34
kgilhooley31
Yes fluid seemed fine that came out I replaced all it. All lines I've made sure aren't pinched or what not. Im thinking internal gear box leak. When I have it up there's no binding, I can turn it on a dime piece of cake. I'm on 35in tires but when I had the 30s on a few days ago (I just upgraded to 35s) there was no difference.
Old Feb 14, 2015 | 07:30 PM
  #35
marcar1993's Avatar
marcar1993
Funny, my 2500 does the same thing. It has a brand new pump and lines. Sometimes at idle its ok, then sometimes it goes rock hard. Just a little roll makes it bearable. Sometimes it goes out while I'm in the middle of turning the wheels.
Old Feb 14, 2015 | 08:30 PM
  #36
kgilhooley31
Do you have any steering play at all?
Old Feb 15, 2015 | 11:32 AM
  #37
Moparite's Avatar
Moparite
There is a special tool used to check flow and pressure of the pump. You may have to go to a dealer and have them check out if the pump is working to spec. Tool # 6815
Just curious but you aren't using atf in it are you?
Old Feb 15, 2015 | 03:26 PM
  #38
kgilhooley31
Using atf as in atf+4 for our trannys? I got just your standard steering fluid in it.
Old Feb 16, 2015 | 10:57 PM
  #39
marcar1993's Avatar
marcar1993
Nope, pretty tight to me, if there's any play its very little.
Old Feb 17, 2015 | 07:52 AM
  #40
onegoodmason
Something else just occurred to me , if the "over the top" adjustment on the steering gear is set too tight , you would have the same issue at idle . I bet it's the issue . It's quite common to see people attempt this prematurely (especially in the jeep world) . Not saying you did it , but , odds are , someone did along the way . Guess what ? It also causes pump failure if too tight . That would cause the restriction issue I mentioned previously . My advice is to back the adjustment off 1/4" to start . Doesn't take much
