Temperature gauge not working
Old 11-29-2014, 01:34 AM
95_dodgeram1500_5.2's Avatar
95_dodgeram1500_5.2
95_dodgeram1500_5.2 is offline
Default Temperature gauge not working
I have the 95 with the 5.2 and my temp gauge don't work at all, no movement. I replaced the 2 wired CTS and that didn't fix it and was told there was a one wire sensor for it but I need help finding it thanks
Old 11-29-2014, 02:13 AM
ryan0714's Avatar
ryan0714
ryan0714 is offline
i think your year only has one sensor, the earlier models like 93 for instance we have 2. if you did u would find the 2nd sensor just to the right of the other one by the t-stat housing. the cluster in the dash could be causing the problem though, i had the oil pressure gauge on mine stop workin and had to install a mechanical gauge.
Old 11-29-2014, 09:49 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,199 Likes on 2,951 Posts
There were two sensor up to 98. (98 and up only had one.) Sensor for the gauge is to the passenger side of the thermostat housing, down near the hose that goes to the heater core.
Quick Reply: Temperature gauge not working
