1998 dodge ram 1500 gauge cluster swap
Old Dec 6, 2014 | 08:37 PM
Deerhunter90's Avatar
Deerhunter90
Default 1998 dodge ram 1500 gauge cluster swap
I'm curious if I could replace my current gauge cluster (that doesn't have a tachometer) with one from the same year with a tach? Direct fit or would I have to modify wiring? Is there a way to reprogram odometer?
Old Dec 6, 2014 | 10:46 PM
Supposedly, it's a direct swap. However, some folks have had little success actually getting the tach to work..... all the wiring is there, but, no signal. It's odd. So far as I know, the programming is already there in the PCM, and it *should* be sending the signal.... but, it doesn't. No clue why. For some it works just fine though, so, certainly worth a shot.
I believe you need a pretty expensive piece of equipment to update the odometer. May be a dealer-only thing.
Old Dec 6, 2014 | 10:57 PM
Deerhunter90
Then I'll go ahead and try it out then. I hate not having a tach and having a fuel gauge that's almost bigger than my speedometer is. Hopefully the dealership won't charge an arm and a leg to correct the mileage.
Old Dec 6, 2014 | 11:48 PM
Old_School's Avatar
Old_School
this is the service i used a few years ago without a problem....
http://www.ebay.com/itm/Cluster-Odometer-Mileage-Programming-Recalibration-Correction-Program-Service-/271668130825?hash=item3f40aeb409&item=271668130825&pt=Motors_Automotive_Tools&vxp=mtr
Old Dec 7, 2014 | 03:27 PM
onegoodmason's Avatar
onegoodmason
Isn't the mileage stored in the BCM and PCM ? I know it is with jeeps , can't see it being different .
I'd think direct swap as long as the truck was 98 or newer with same digital odometer .
Old Dec 7, 2014 | 08:20 PM
Not sure on that... some folks have done this, maybe one of them will chime in......
GM stored it in the cluster.
Old Dec 7, 2014 | 08:47 PM
Deerhunter90
I found a cluster on ebay and they claim they can put correct mileage on it before it ships, for $60 for the cluster it'll be worth trying. I still don't understand why the fuel gauge is so big (or why the distributer cap is in such a stupid place but I'll save that rant)
Old Dec 7, 2014 | 09:48 PM
The gas gauge is all about geometry. The larger diameter gives the needle a longer sweep, so you can't actually watch it move, like you can the smaller ones......
Old Dec 7, 2014 | 10:23 PM
Deerhunter90
That makes sense, I always assumed it was for the elderly who can't see.
Old Dec 8, 2014 | 08:14 AM
That's just as likely. I was being facetious in my earlier post.
