Blew transfer case to pieces
Old Dec 11, 2014 | 03:07 PM
100dollardodge's Avatar
100dollardodge
Default Blew transfer case to pieces
Need help recently hit a fence in my truck (being a dumb ***) going to school the pole hit my front drive shaft and completely blew my transfer case to pieces the truck drove to my work and has been sitting i need help on finding a good cheap used transfer case if anyone could help me id appreciate it my truck is a 1996 dodge 2500 5.9 360 my transfer case is a 241 DLD 5210 5369 serial number is 725 and gear ration is 272 thank you guys!
Old Dec 11, 2014 | 03:16 PM
Craigslist, EBay, local wrecking yards, newspaper ads. Best you can do. Can also look for whole trucks that people are parting out. T-cases tend to go quickly though....
Old Dec 11, 2014 | 03:25 PM
100dollardodge
2 yards have my t case but they want 650 for a used one with 212,000 on it the other yard wants more i would just rather pay the 800 for a new one i was hoping to get one cheaper. everyone wants top dollar for these things there must be gold inside of it
Old Dec 11, 2014 | 03:34 PM
You would think so. There weren't quite as common as the 231's..... You could also look for a 241DHD out of a V-8 engined 3/4 or 1 ton. The V-10, and diesel versions have different input shafts I think.
Old Dec 11, 2014 | 03:38 PM
100dollardodge
my shafts are fine my gears are fine everything works and isnt broken just the cases have 5 inch holes and my spedo wont work (fence broke it off)
Old Dec 11, 2014 | 03:40 PM
Ham Bone's Avatar
Ham Bone
A 231 will bolt right up to your truck.
So a t case from an auto 1500 will work
That will expand your options if getting back on the road ASAP is the priority
Assuming you have an auto
Since you have a 96 your years are limited to 94-97ish because sometime then they switched the Speedo to the rear axle.
Old Dec 11, 2014 | 03:54 PM
100dollardodge
thank you i dont really need my spedo my truck only likes one speed and its 70 mph lol i will look around for some
Old Dec 11, 2014 | 06:02 PM
JSTMoto's Avatar
JSTMoto
Try http://www.car-part.com
I did a random zip in PA and came up with quite a few hits. The yards' phone #s are in the listings. Should give you some good leads to call on but pay close attention to the descriptions.
Old Dec 12, 2014 | 10:09 AM
Sheriff420's Avatar
Sheriff420
http://www.mintonmotorsinc.com/ They should have what you need.
Old Jul 29, 2015 | 01:20 AM
Pelsion's Avatar
Pelsion
The code on my 1996, dodge, 2500, cummins diesel, automatic, regular cab, 4x4, has a bad transfer case. I live near Tacoma wa. The t case # is 241 DLD 5210 5369. Like mentioned above regarding the A231
Is there another t case that will work for mine? If so which code would our be?
