Do 46/47RE trans turn on the CEL with codes? (98)
Old Dec 15, 2014 | 05:48 PM
dodgetrucker75's Avatar
dodgetrucker75
Default Do 46/47RE trans turn on the CEL with codes? (98)
in a 98, if the transmission has codes, will it turn on the CEL?
Old Dec 15, 2014 | 06:01 PM
dodgetrucker75
i guess i should provide a story... the 98 has been swaped from a RE trans to a manual, the CEL is on but also has a EGR code, i can cure the egr code, and if that turns off the CEL, i'll be in buisness... if the trans codes keep the CEL on, i either have to find a way to fool the PCM or change out the PCM for the corect manual PCM, but that gets costly, and cant pass smog with the CEL on in this POS of a state
Old Dec 15, 2014 | 06:04 PM
An EGR Code? But, your truck doesn't even HAVE EGR......... That one always confuses me.
Trans codes may or may not turn on the lite. Just depends on the code. Since you don't even HAVE the auto trans any more, you are going to have a HOST of codes for it, and chances are REAL good, that will also turn on the lite. You can get a PCM for a manual trans truck, and have it flashed to your vin, or, you can get a tuner, that just has manual trans tunes on it, and solve the problem that way too.
Old Dec 15, 2014 | 06:14 PM
dodgetrucker75
the truck is actually a 98 12v cummins, california truck WITH EGR....
it has 5 codes i believe... just looking for an answer on the trans codes before i spend time and $ on the egr fix, if the CEL stays on, it will be a waist, otherwise its about $600 for the PCM
Old Dec 15, 2014 | 06:17 PM
Ok, missed that little tidbit. Makes a difference.
Check with your local parts store for a PCM..... I think they have them for 250 or so. Of course, those are for gas engines.... diesel may be more expensive. Don't know.....
Old Dec 15, 2014 | 06:29 PM
dodgetrucker75
ya its near $600 for the correct pcm loaded and ready to go for these things
Old Dec 15, 2014 | 06:35 PM
Ouch.
I don't think there ARE any manual trans codes, though, the wiring harness is different. So, you could supposedly just replace it with a manual trans PCM, and be golden. I think. (pretty sure.)
Old Dec 15, 2014 | 06:40 PM
dodgetrucker75
Ouch.
ya the convrsion on my 98 is running a manual PCM with an auto harness and it is perfect, just had to ground the nuetral start wire and connect the reverse lights, but this mess is on a buddies truck, we are trying to fix for him
