Coil spacers
Old Dec 18, 2014 | 02:47 PM
  #21
$A_Money$'s Avatar
$A_Money$
It's my personal truck that I ride back an forth to work in its got 33s now with no lift....I'm gon keep 33s but I just want it higher so it can flex some plus I want it higher just in case I got 35s s that it can still flex some
Old Dec 18, 2014 | 03:07 PM
  #22
Johnn123's Avatar
Johnn123
Originally Posted by Wh1t3NuKle
You read that correctly Merc old buddy. Fabtech is another one to put in there. Anything you have to buy in Canada is more expensive down here anyways. They are economy kits from my perspective. Just sharing my thoughts for the OP, same as yourself. It's the pocket book that rules.
There is no way in hell parts are more expensive down there than they are up here. Lol. There is a reason so many Canadians order all their auto parts online... myself included. I will not buy local for this reason, it is simply to expensive. If you think parts are expensive down there you would have a heart attack if you tried to buy the same thing up here. Tires cost average 30-40% more up here than south of the border, not a word of a lie. Its not even just parts, Canadians pay more for everything up here. Gas costs us far more than you guys pay.
Not attacking but it is simply not true that Americans pay more than Canadians for parts.
Not to hijack the OP thread!
OP as said do not get 4-5" coil spring spacers! Get a proper kit. You can go up to 3" no problem before you get into track bars, pit man arm drops, control arms, etc. Get an add-a-leaf also if you are wanting more than an inch or two out back, and if you go the block route get a taller block instead of stacking them. If its 35's you want you will need a 5" lift as a rule of thumb to clear them.
Old Dec 18, 2014 | 03:12 PM
  #23
If you want to run 35" tires, then you should get at least 5" of lift.
Old Dec 18, 2014 | 08:29 PM
  #24
$A_Money$'s Avatar
$A_Money$
So wut size blocks in the rear it has factory blocks like 1inch I guess.....so now how to lift the front?
Old Dec 18, 2014 | 09:02 PM
  #25
merc225hp's Avatar
merc225hp
Factory rear blocks in the 1500 2nd gen Ram 4wd are 3" tall.
So for the front
5" lift coil-springs Skyjacker part number is D50
Shocks
Upper and lower control arms (White Knuckle has a set for sale)
Drop pitman arm
Trackbar or drop bracket for said lift height
Brake lines
Rear 3" add a leaf kit (long spring)
New shocks
Old Dec 18, 2014 | 10:08 PM
  #26
Does the rear need a longer brake lines as well at 5"?
Old Dec 18, 2014 | 11:58 PM
  #27
merc225hp's Avatar
merc225hp
Yes/No you can mess with the bracket on the frame to get the added slack you need. Most kits come with an extension for said bracket.
Old Dec 19, 2014 | 08:24 AM
  #28
$A_Money$'s Avatar
$A_Money$
So I cant just grt coil springs? I can get some lift springs kinda easy
Old Dec 19, 2014 | 12:31 PM
  #29
merc225hp's Avatar
merc225hp
Yes lift coil-springs. You can't just put these in by themselves the other parts I listed must be used as well.
Here this is a Skyjacker 5" 1500/2500 V8 gas coil-spring on one side and a 8" BDS DSl coil-spring on the other side.
Old Dec 19, 2014 | 12:37 PM
  #30
Johnn123's Avatar
Johnn123
Merc is very correct OP. When you lift up, you're actually shifting the axle as well. Longer control arms re-center to it to where its supposed to be. Drop brackets are necessary for the track bar and pitman arm to keep steering kosher and keep the angles right on them. Shocks need to be longer to accommodate the lifted height, same with brake lines.
