wiring questions....
Old Dec 16, 2014 | 05:40 PM
dipsherry's Avatar
dipsherry
Default wiring questions....
just finished putting in my motor and guy who was doing it before had wiring ran. so i am confused as to where these two wires go on the fuse box... also the alternator wire was not ran and i belive this one to run to the battery???
Attached Thumbnails wiring questions....-fuse-box.jpg   wiring questions....-alternator.jpg
Old Dec 16, 2014 | 05:58 PM
Alternator wire goes to the power distribution box, to the same terminal the positive battery cable goes to.
I am not sure which two wires you are referring to in the first pic.
Old Dec 16, 2014 | 06:04 PM
merc225hp's Avatar
merc225hp
Mines on the other one lol and I have never moved it. After the fuse or before it hummmm
Old Dec 16, 2014 | 06:10 PM
dipsherry's Avatar
dipsherry
i mean the two big wires on the fuse block. Does one go positive and one negative?
Old Dec 16, 2014 | 06:12 PM
dipsherry's Avatar
dipsherry
when i first got the truck thats how the guy had it hooked up and i dont know how that would work but the truck did run.
Old Dec 16, 2014 | 06:30 PM
merc225hp's Avatar
merc225hp
No Batt negative leads go to the PDB.
Off my batt + terminal, one wire goes to the starter, one goes to the PDB (first stud).
Before the fuse (first stud) goes the batt 12v+ supply wire, other stud is alt amp out, thats it one wire per stud.
ryan0714's Avatar
ryan0714
+1 what merc said
Old Dec 16, 2014 | 06:32 PM
dipsherry's Avatar
dipsherry
thats what i was thinking thanks...
Old Dec 16, 2014 | 06:33 PM
dipsherry's Avatar
dipsherry
this prolly explains why i burned up two PCM's before checking the damn wireing.
Old Dec 16, 2014 | 06:36 PM
merc225hp's Avatar
merc225hp
Thats not good sorry to read that. I would expect the ckps and cam-sensor is toast as well maybe more.
