98 ram 1500 sensor on transmission tail leaking
Old Dec 18, 2014 | 08:17 AM
Deerhunter90's Avatar
Deerhunter90
Default 98 ram 1500 sensor on transmission tail leaking
I changed my oil on my 98 dodge ram 1500 and while I was under the truck I noticed that there's a small sensor (vss sensor?) that's located on the tail end of the transmission that was damp with trans fluid, is this the vss sensor? Is it common for them to leak? Lastly am I going to take a transmission fluid bath when I yank it out of there to replace it?
Old Dec 18, 2014 | 03:45 PM
Think that would be the trans output speed sensor. I don't *think* you get a lot of fluid out of the hole when you pull it, but, be prepared for that anyway.
I believe its just an o-ring seal there too...
Old Dec 18, 2014 | 04:12 PM
merc225hp's Avatar
merc225hp
+1 HeyYou
Nothing will come out and yep just an o-ring, I looked for a part number for the o-ring but no luck in the Dodge parts book anyway.
Old Dec 18, 2014 | 04:42 PM
Deerhunter90
Very good. Local transmission shop told me I'd loose all of the fluid but they also told me I had a 4l60e transmission in my dodge even after looking at it so I think someone's had a few to many to be taken seriously.
Old Dec 18, 2014 | 05:06 PM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by Deerhunter90
Local transmission shop { ... } told me I had a 4l60e transmission in my dodge even after looking at it { ... }
Don't ever let those monkeys near your truck with tools! Heck, if they just want to ride in it you should put them in the bed like flea bitten dogs.
Old Dec 18, 2014 | 05:17 PM
Deerhunter90
That's exactly why I perfer to do all of my own work, transmission stuff is alien to me but even I know I've got the 42re transmission in it, 4l60e is General Motors I think...
Old Dec 19, 2014 | 02:29 PM
merc225hp's Avatar
merc225hp
You have a 46re
Pix of VSS out of the xcase.
Old Dec 20, 2014 | 08:00 AM
Deerhunter90
I thought the V6 came with the 42re and the V8s came with the 46re
Old Dec 20, 2014 | 08:26 AM
onegoodmason's Avatar
onegoodmason
I was quite surprised too but all listing I can find point to that conclusion .
Old Dec 20, 2014 | 10:22 AM
Deerhunter90
I'll know for sure when I crawl under it to change sensor, I believe the 42re had a flat pan and the 46re had a slightly curved pan, I'm anxious to get this sensor done so I can start on my 2nd gen lil red express clone project.
