o/d light comes on shortly after trans temp light comes on
Old Jan 1, 2015 | 10:31 AM
kylekiern94's Avatar
kylekiern94
Default o/d light comes on shortly after trans temp light comes on
I have a 2001 dodge ram 1500 5.9 4wd 106,000 miles, this morning I was on the expressway 10 miles or so were good then the overdrive light kicked on and kicked it self out of over drive shortly after that the trans temp light came on, I have replaced the 3 solenoid's inside the trans not the wire harness on top of the valve body and removed the check valve, what could that be?
Old Jan 1, 2015 | 11:25 AM
Welcome to DF.
Probably wouldn't hurt to disconnect the cooler lines from the trans, and make sure you can get good flow thru it. (backflush it. Can't hurt.)
Did you replace the pressure sensor as well? If the wrong part was installed, it gives the wrong signal to the PCM, and this is what you end up with. Or, it may have failed....
Old Jan 1, 2015 | 12:23 PM
kylekiern94
Thanks for the feed back, I never replaced the pressure sensor, never knew there was one of it is possible where is it located?
Old Jan 1, 2015 | 12:48 PM
kylekiern94
If your talking about the governor pressure solenoid I did replace that.
Old Jan 1, 2015 | 03:55 PM
Solenoid and sensor are two different parts, but, they are both within a couple inches of each other. Shoulda been in the same general vicinity as the solenoid.
Old Jan 1, 2015 | 04:48 PM
kylekiern94
Yes sensor was replaced
Old Jan 1, 2015 | 08:38 PM
You have the symptoms of having the wrong one. Got a receipt with a part number?
Old Jan 2, 2015 | 01:15 AM
kylekiern94
That I could not verify, I know that the sensor and all solenoids were putback in with original parts, I was told it was the torque converter "going".
Old Jan 2, 2015 | 08:18 AM
Does the torque converter clutch slip?
Things changed for the pressure sensor in 00. If they put in the wrong one, it will give you those symptoms. Did you do it? Or did you have a shop do it?
Old Jan 2, 2015 | 10:19 AM
kylekiern94
I did it, but it was doing this same thing before I replaced those parts and as far as I know it doesn't slip it locks up then goes in to O/d.
