Cyl 8 compression lower than the rest.
Old Jan 25, 2015 | 07:20 PM
tbone360's Avatar
tbone360
Default Cyl 8 compression lower than the rest.
Hey all. I did a compression test for the heck of it cylinders 1-6 were all 130. Cylinder 7 120 and cylinder 8 was 100. Wet test differences were miniscule. Barely any change. Unless i did something wrong. I followed the procedure in the Haynes manual. So do I have a major problem? Truck is a 99 1500 RWD 5.9 with 99xxx miles. Plenum done 2 years ago with no problems since except a little bounce in rpms at idle. So please let the comments fly. Thanks
Old Jan 25, 2015 | 09:18 PM
UnregisteredUser's Avatar
UnregisteredUser
That's a classic symptom of a cracked head. The most common cause of it is a blown plenum gasket fouling the catalytic converter -- #8 is closest to the cat, so it feels the most heat when the exhaust flow is restricted.
Old Jan 25, 2015 | 10:44 PM
tbone360's Avatar
tbone360
Thanks uu thats kind of what I was thinking. So it looks like a pair of clearwater heads are in my future.wooopie.
Old Jan 25, 2015 | 11:47 PM
Don't forget to fix the root cause of the problem, and swap out the cat, and O2 sensors as well.
Old Jan 26, 2015 | 12:27 AM
tbone360's Avatar
tbone360
How long do yo guess it can last in this condition? It get driven 8 miles a week. I have to do some serious saving for this project.
Old Jan 26, 2015 | 09:59 AM
Ham Bone's Avatar
Ham Bone
do a wet compression test. See if the numbers jump up. No need to put new heads on worn out rings.
Ooops I see you already did that haha
You can drive it till it starts spewing a cloud of coolant and oil out the tail pipe.
Old Jan 26, 2015 | 04:05 PM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Agreed, drive it till it won't drive it till it won't drive no more. Save your pennies until then.
Old Feb 4, 2015 | 10:15 AM
whitesquirrel45's Avatar
whitesquirrel45
Just wondering if I have the same problem. Started as a cylinder 8 misfire CEL light would come on and flash if I got it over 2500-3000 rpms. And shudder something fierce. Did plugs wires cap and rotor air filter oil change. All plugs looked terrible but #8 was by far the worst. After i changed all of that, the light went away and hasn't been back since (approx. 6 months ago) Question: Would this be the same problem? Also I've noticed oil burning around the top end of the motor on the left side, hopefully a valve cover gasket? And should I have made my own thread? Im new and Ive been creepin round here and getting awesome, helpful info you guys seem to know your stuff. Thanks!
Old Feb 4, 2015 | 02:09 PM
tbone360's Avatar
tbone360
Have you fixed your plenum gasket yet?
Old Feb 4, 2015 | 03:40 PM
whitesquirrel45
No. But after reading the plenum sticky, i think I will be.
