Torque converter issues
Old Jan 28, 2015 | 09:37 PM
Real possibility they used the same part across many engines. The spring in it should attempt to hold the throttle closed. Do you just need to stick it on there, and then rotate it so the bolt holes line up?
Old Jan 29, 2015 | 07:45 AM
J-Ham's Avatar
J-Ham
The one I got had the same paper in it saying it was for the a 4.7. When comparing the old one to the new one they were identical. I used the TPS anyway and it's been working like normal. I can only assume they used the same part for both applications.
Old Jan 29, 2015 | 08:14 AM
Blue Mopar01's Avatar
Blue Mopar01
I didn't have to rotate it to line up the bolt holes. JHam if yours was the same, I'll just run this one then and see what happens.
Old Jan 30, 2015 | 04:36 PM
Blue Mopar01
Well the new tps didn't work for me. Truck died about 20 ft after I drove it. The truck would almost die after I got it moving and got off the throttle. CEL came up for the tps as well. So I just slapped in the old tps so I could leave. I didn't check any voltage for the new tps. Anybody else help out? Maybe a faulty new tps
Old Jan 30, 2015 | 09:24 PM
Did you reset the PCM when you installed the new TPS? IT needs you to do that, so it can figger out what the value is now at closed throttle.
Old Jan 30, 2015 | 09:42 PM
Blue Mopar01
Yep I disconnected my negative terminal both times.
Old Jan 30, 2015 | 09:47 PM
OK. Have you cleaned the throttle body? Done anything with the IAC?
Old Jan 30, 2015 | 10:05 PM
issakar's Avatar
issakar
sub'd to see how this pans out
Old Jan 31, 2015 | 01:42 AM
snowboundrmk's Avatar
snowboundrmk
Like HeyYou said you should have to rotate it slightly against the spring to get the holes to line up.
Old Jan 31, 2015 | 07:47 AM
Blue Mopar01
Yep my t body is sand blasted cleaned so that's good. When I get back to my truck tomorrow I'll check things out better. I'll keep an update.
