Lifters on a 360.
Old Feb 2, 2015 | 12:17 PM
Ham Bone's Avatar
Ham Bone
The stock lifters are about as good as they get anyway
Old Feb 2, 2015 | 03:04 PM
zgravity's Avatar
zgravity
Default Lifters
Erm, are you SURE it's your lifters you are hearing, and not spark knock? (sounds VERY similar.) I would bet real money your plenum is blown, and you are actually hearing the spark knock... would be a real bummer to spend that kind of money, and NOT fix the problem.
What does your oil pressure look like?
Oil pressure is between 30 to 50 PSI. When she starts up cold it sits at 50 PSI. Then when it warms up it sits at 30 PSI. When I drive is rides around 40 PSI. depending on the speed I'm at.
Let me know if that is normal for this engine. I had a Tundra that use to go from 20 to 60 PSI depending on idle and speed and it was fine.
Old Feb 2, 2015 | 05:02 PM
Oil Pressure sounds normal. Pull of the air box, crack the throttle wide open, and look down into the intake. (engine NOT running) I bet you see oil.......
Old Feb 4, 2015 | 09:46 AM
Ramman18's Avatar
Ramman18
Ping sounds like marbles in a can being shaken. Lifters sticking sound like air pressure popping (at least when mine did). Put some Seafoam in the crankcase for a week before your next oil change, then put in MaxLife 10w40. Cured my lifter and that was 4 years ago. I agree the lifters should not be replaced unless you're doing a new engine anyway.
