New guy here need help with running problem
Old Mar 17, 2015 | 08:35 PM
  #51
Map not changing with throttle position could be an issue...... Can you apply vacuum directly to the map, and see the signal change?
Old Mar 17, 2015 | 08:41 PM
  #52
Largefarva's Avatar
Largefarva
Vacuum reading does not change, no. I'm thinking its a problem with the scanner though, unless the PCM isn't converting it into inches of vacuum. But both computers do the same thing.
It's a 3-wire sensor, it communicates to the PCM via a voltage change depending on the vacuum reading, right? I can see the voltage changing, even on the scanner, but it has a reading for vacuum, which does not change.
Old Mar 18, 2015 | 10:25 AM
  #53
You are correct on how it is supposed to operate... I am real curious why the PCM doesn't think pressure is changing though. That's not quite right. That isn't for barometric (atmospheric) pressure by any chance is it? (I don't think our trucks have a baro sensor though..... I've never seen one.....)
Old Mar 18, 2015 | 11:26 AM
  #54
Moparite's Avatar
Moparite
Map sensor is for reading air density. It tell the pcm where you are (sea level or high up in the mountains) for correct air fuel mixture.
Old Mar 18, 2015 | 01:31 PM
  #55
Barometric pressure sensor there.
MAP sensor is "Manifold Absolute Pressure." Reading should change with engine vacuum.
Old Mar 18, 2015 | 06:04 PM
  #56
Largefarva's Avatar
Largefarva
Does not change, but voltage changes, this really makes no sense....I'm gonna throw on in tomorrow.
Old Mar 19, 2015 | 01:31 PM
  #57
Moparite's Avatar
Moparite
Yes barometric! voltage should change with different vac readings.
http://www.aa1car.com/library/map_sensors.htm
Old Mar 19, 2015 | 05:57 PM
  #58
Largefarva's Avatar
Largefarva
Ya, voltage does change but can't see a vacuum change on the scanner. Ordered one for tomorrow, will update with the results.
Old Mar 20, 2015 | 05:47 PM
  #59
Largefarva's Avatar
Largefarva
New map sensor, no change. It can't be this hard....I have everything I need,Nagy does it not run?
Old Mar 20, 2015 | 07:26 PM
  #60
Just out of idle curiosity, what spark plugs ya got in there, and how old are they?
