Blower setting knob
Old Feb 5, 2015 | 04:09 PM
2001Off-Road's Avatar
2001Off-Road
Default Blower setting ****
The settings for the strength of the blower are 1 2 3 4. 1 has not worked for some time. 2, 3, and 4 have always worked until this morning. Now, only 4 works. So, the only way to have heat is to have it blasting on 4. I was hoping someone could give me a clue as to where to start and what to do. Thanks!
Old Feb 5, 2015 | 05:12 PM
Resistor block for the blower motor. If you look under the dash on the passenger side, there is a wire from the blower motor, that goes to the bottom of the heater box, and a bunch more wires coming out. That's the resistor block. Replace it.
Old Feb 6, 2015 | 10:51 AM
jmhd1989's Avatar
jmhd1989
100% resistor. +1 HeyYou
Old Feb 6, 2015 | 01:33 PM
2001Off-Road
Thanks guys. I am going to pick one up today and replace it. You guys are a huge help!
Old Feb 19, 2015 | 07:24 PM
2001Off-Road
Ok. You fellas were right. The blower issue was fixed by replacing the blower motor resistor. Now, here's the new problem. The new one that I installed is now not working. The little strip of metal, that works as a fuse I suppose, came apart. So, I replaced the replacement, and now the newest one has quit working. Although I have not taken it out yet, I assume that it is the same problem. It just happened so I have not had time to check it out, plus it is dark outside. So, what in the world could be cause those metal strips to blow????
Old Feb 19, 2015 | 07:44 PM
2001Off-Road
Oh, and by the way, there is usually a strange burning smell....
Old Feb 19, 2015 | 08:47 PM
Wonder if you have a bad ground. It shouldn't eat them like that.
Old Feb 22, 2015 | 03:37 PM
2001Off-Road
I am going to install a new blower motor and resistor and I will update on the issue. Thanks.
Old Mar 4, 2015 | 06:42 PM
2001Off-Road
Ok. I had heard that burning smell was the factory blower motor pulling to much amperage through the replacement blower motor resistor. Also, I had heard that this was an issue and that these two parts really should be sold in pairs. When you replace the resistor, replace the motor. I bought a pair together and installed them and I have not had any more issues.
Old Mar 4, 2015 | 07:36 PM
jmhd1989's Avatar
jmhd1989
thanks for the follow up
