I screwed up band adjustment
Ok I had another issue with it dying while driving it would miss. Once it died it would say no bus. So after redoing all my grounds well most of them. It turned out to be a blue plug on the back of fuse panel was loose. So I took it out and plugged it back in fixed for now. When it runs fine the trans seems to act fine but when it runs fine it shifts fine drives fine. I'm sure the trans isn't too long for this world but if I can get through taxes then I'll prolly be ok. This has been a huge improvement over the slipping not moving it was exibiting before the filter change
