Icon forged Pistons 1997 Stroker 408
Old Feb 24, 2015 | 10:26 PM
Magnumater's Avatar
Magnumater
Default Icon forged Pistons 1997 Stroker 408
Any idea what would cause this? I'm getting different stories from different parties. It went from "piston slap" to a knock. 2000 miles on new engine.
Builder blames tuning, tuner blames builder .....
Old Feb 24, 2015 | 11:03 PM
UnregisteredUser's Avatar
UnregisteredUser
I've only ever personally known two causes of that kind of damage. One is that completely asshat "drive it like you stole it" break-in method, and the other is Budweiser's Revenge (careless builder).
Old Feb 25, 2015 | 12:28 AM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Sorry I can't say anything more than Unreg said. Doesn't look good though so I hope you can get things worked out and your engine back running again.
Old Feb 25, 2015 | 01:36 AM
onegoodmason's Avatar
onegoodmason
I don't see how a tuner does that to a crank bearing !
Old Feb 25, 2015 | 11:12 AM
Magnumater's Avatar
Magnumater
Ive owned this truck since new and have never had a chance to really drive the new engine due to issues with tuning,20 plus tunes and it still wants to quit when I slow down.
So no i didn't break it in like I stole it. the engine at this point has only 2000 miles.
and the damage to the top of the rod bearing, from what I've been told, is caused by excessive down force on the piston, in a miss tuned ignition timing. Im just repeating what I've been told and hoping for other insightful views on this. this
Old Feb 25, 2015 | 11:16 AM
Ham Bone's Avatar
Ham Bone
Lots of and lots of hard misses beat on on the rod bearings?
I would blame builder. Budwiesers(yuck) revenge
Old Feb 25, 2015 | 12:23 PM
Were you hearing spark knock? How do the crank journals look?
Old Feb 25, 2015 | 12:58 PM
Wildman4x4nut
Veteran: Army
Here is what one bearing looked like in my 408 with 4,000 miles on the engine. The PO had a plenum leak so he was burning a lot of oil too.
And here is the top of one of the pistons so you can see the built up carbon for just short miles.
And then here is a cam bearing for ya.
Old Feb 25, 2015 | 01:33 PM
Wow, those cam bearings are scuffed pretty bad. What happened there??
Old Feb 25, 2015 | 05:22 PM
Wildman4x4nut
Veteran: Army
HeyYou,
No idea why any of the bearings look as bad as they do. But this is why I am rebuilding the 408 instead of just dropping it into the Jeep. And I am going to follow Hughes Engines advice on how to install the cam bearings plus am going to drill out the oil passages.
Oiling system:
Small Blocks
Many times the mounting surface for the oil pump on the main cap is not level. Grind or mill it flat and do not use a gasket.
The oil passage from the pump does not line up with the passage in the main cap. Grind out this “stepover” area in the cap to
prevent a restriction here. The 360” is worse than the 340”. Restrict the oil flow through cam bearings #1 - #3 - #5 only by drilling a
new 1/8” oil hole in the cam bearing and then install bearing with this new, smaller hole aligned with the feed passage from the
mains. Run a straight ¼” reamer(our P/N 8350) completely through the main bearing oil feed passages #1 -#3 - #5 coming down
from the right hand lifter oil galley. Run a 9/32” reamer (P/N 8352) completely through the #2 - #4 main bearing feed passages. The
intersection of the large threaded oil passage, from the center of the oil filter to the main passage running to the rear of the block is
very rough in many cases. Smooth out all the rough spots and sharp edges in the intersection. Do not attempt to drill the passages
deeper. Water is close by.
If you are using our main stud girdle, it needs to clear all rotating parts by .030”.
A standard volume oil pump will supply enough oil to a 700 HP engine with the above modifications, a windage tray and 5
quarts of oil in the pan. We suggest our oil pan P/N 20710 for 340’s and P/N 20730 for 360’s; both use screen, P/N #6907. For more
ground clearance you can use pan #31590 on the 340 and 31595 on the 360. Position screen 5/16” to 3/8” from the bottom of the
pan. Oil pressure of 9# per 1000 RPM is adequate. Maximum pressure over 65 P.S.I. is not recommended.
This is from #9 Stroker Kit Instructions & Tips
Which opens up into this PDF And the info about oiling system is on page 2.
For the OP have you seen this info before?
