Prepping for Plenum fix/tune-up, do I have it all?
Old Feb 28, 2015 | 11:04 PM
  #21
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Placed an order there last night! I also use Amazon, which has good prices on some parts.
Old Mar 26, 2015 | 11:11 AM
  #22
schmidtp's Avatar
schmidtp
Originally Posted by ryan0714
maybe new NTK o2 sensor on the upstream? and possible a new double roller timing chain since your right there...its only like 5 more bolts after the water pump
How crucial is it to use "NTK" rather than using "Ultra-Power" the cheaper alternative? I am getting a shopping cart together on RockAuto
Old Mar 26, 2015 | 11:16 AM
  #23
schmidtp's Avatar
schmidtp
Which timing chain would be the correct one to use?
Attached Thumbnails Prepping for Plenum fix/tune-up, do I have it all?-timing-chain.jpg
Old Mar 26, 2015 | 03:14 PM
  #24
Our trucks really don't care for the no-name O2 sensors. Don't particularly like Bosch either. NTK or Denso please.
You want the first one, 9147.
Old Mar 26, 2015 | 03:30 PM
  #25
schmidtp's Avatar
schmidtp
Thank you sir. Here is my shopping cart, I am going to pick up the Autolite 3923 from Walmart because I did not see them on RockAuto. Anything I am missing? Certain gaskets maybe?
Edit: Oops, noticed I had the 180 degree thermostat, changed to 195
Old Mar 27, 2015 | 08:55 AM
  #26
Moparite's Avatar
Moparite
What is the wire mm? I would get 8mm minimum. Double check the NTK o2 #'s. It took me a while to figure out witch ones where right for mine. They come in two different lengths. My 96 took 23014 front and 23151 back.
Old Apr 2, 2015 | 04:04 PM
  #27
schmidtp's Avatar
schmidtp
I am trying to find out which is correct for mine since I wanted to just order all my stuff off RA. How come there are multiples for the right and left?
Attached Thumbnails Prepping for Plenum fix/tune-up, do I have it all?-o2-sensors.png
Old Apr 2, 2015 | 05:54 PM
  #28
Connector shape, I do believe. See which ones you have, and make sure you order the correct ones.
Old Apr 3, 2015 | 11:25 AM
  #29
Moparite's Avatar
Moparite
Yea connectors and wire length. Look at yous and find out what you have before ordering. The #'s that ra gave me for my truck where off so i had to research it.
