drilling front pinion bolt hole?
Old 02-25-2015, 08:27 PM
cutthroatxxx's Avatar
cutthroatxxx
cutthroatxxx is offline
none of the auto parts stores can get it I have to order the full drive shaft with it. Plus I have to have it on the road by 5 a.m. Or my wife will lose her job
Old 02-25-2015, 08:31 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,198 Likes on 2,950 Posts
Have to order the full driveshaft with it???? Someone at the parts store is confused. It's bolts to the end of the pinion gear...... a u-joint hooks into it..... even a brand new driveshaft wouldn't come with it....... I would try a different parts store, and make sure the person you talk to has a clue....
For temporary though, drill it out, use a longer bolt, and nut. Spin it a few times to make sure it isn't going to hit anything. Order up the pinion yoke.
Old 02-25-2015, 10:03 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is offline
Let me look in my garage and see if I still have any of the old yokes I pulled off. I swapped the one I had on my D44 for a u-bolt yoke instead of the strap and bolt type as they do not hold up as well.
If I have one I'll send it your way.
Old 02-25-2015, 11:47 PM
cutthroatxxx
that would be awesome I don't have Paypal but I can order something online and send it to you as payment
Old 02-26-2015, 12:05 AM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Have you tried going down to a self-serve salvage/junkyard and picking one up? It would likely cost less than $20 at one of our local pick and pay yards here.
Old 02-26-2015, 04:10 AM
Wildman4x4nut
I need you to count the splines on your pinion and make sure it is 29 splines. If it is I can get you a yoke.
PM me your address and we can deal with payment later. Let's just get you on the road.
Old 02-26-2015, 09:21 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
Agreed for the time being since you said get the wife to work ASAP, get a full bolt and nut on there to lock it down.
For the pinion yoke, are we talking about the one in your profile, 99 2500 Diesel?
Gotta know which yoke is yours --
http://www.quad4x4.com/qk4653.html
Put up some pictures?
You are in Missouri?
Slap the parts guy for saying to get a whole new driveshaft, then drop kick him all the way to where the truck is sitting for him to look at it. lol
Old 02-26-2015, 12:30 PM
Wildman4x4nut
Yes WK is correct we need a little more info to really help you out.
What size u-joint do you have? That matters. Spline count on your yoke is important too. The one I have is for a 1350 u-joint as that is the size I am using on my Jeep.
We are all here to help just give us some more info.
One other thought, you could pull the yoke and take it to a machine shop and have them drill it out just a little bit and then run u-bolts instead of straps
Old 02-26-2015, 01:19 PM
oxymoron29's Avatar
oxymoron29
oxymoron29 is offline
Just take off the front shaft until you can fix it properly...
Old 02-26-2015, 05:01 PM
Moparite's Avatar
Moparite
Moparite is offline
just take off the front shaft until you can fix it properly...
x2! .
Quick Reply: drilling front pinion bolt hole?
