Dana 70 conversion ABS & speed sensor
Old Mar 10, 2015 | 11:59 AM
dman12323's Avatar
dman12323
Default Dana 70 conversion ABS & speed sensor
Hello again, I haven't been on here in a good while so hello again everyone! I finally got a Dana 70 from a 73 chevy rv of some sort. Its a steal new bearings,new brakes and only used 3 times its whole life still looks brand new. Its been sitting for like 19.6 years though I think.Has 4.88 gears with the power lock. Anyways my first question has to do with the speed and abs sensor. I have a 1998 Dodge Ram 1500 4x4 and the speed and abs sits on the rear diff pumpkin. Unfortunately the Dana 70 does not have the hole for the sensor inputs. Would I need to get a digital speed interface such as the dakota digital sgi-5 or can I just drill 2 holes into the pumpkin near the gear ring? Also I know they don't make a ujoint from 7290 to 1410 is it easier to just have a 1410 welded to the drive shaft? or should I just get a 7290 yoke for use with the stock axle. Thats the only 2 questions I have so far haha. The axle had the springs perches and custom shock brackets made and welded for use with the stock 1500. There ready to go as soon as I get the wheels in. Thanks for the help!
Old Mar 10, 2015 | 12:23 PM
Can't just drill the hole for the rear wheel speed sensor, as there is no tone ring inside the diff for it to read. Have to come up a different solution.
Change the yoke on the rear diff to use your current driveshaft. Welding things on the d/s is just a bad idea.
Old Mar 10, 2015 | 12:40 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
LOL
People have drilled and mounted the VSS sensor in the diff. Just get it in the right spot.
Get the tone ring for the carrier, then you'll have to reset up the gears. This is b/c the tone ring will offset the ring gear.
Going that route does not need the Dakota Digital.
Dakota Digital is used only if you have a pulse input already but it doesn't match the factory intervals for the speed calibration. The box is then used to calibrate. To use this option you need something spinning and to pulse. Example would be a tone ring on the driveshaft with the VSS mounted to sense it. Then the dakota digital spliced in. That's one way to accomplish it....
Old Mar 11, 2015 | 11:12 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Your best way to accomplish this, I think, is to get a SYE kit for the tcase 231 that has a speed sensor in it. Like this: http://www.jbconversions.com/product...1j_std_sye.php
Call them for application as well as other Vendors. Advanced Adapters has one too.
This will allow you to put the Dakota Digital in-line your factory VSS wire and the new SYE sensor.
Also, you'd upgrade the driveshaft to a double cardan at the tcase and have 1410 at the axle.
No need for tone ring on ring gear.
Old Mar 15, 2015 | 01:50 PM
dman12323's Avatar
dman12323
Well im prob going to end up installing the toner ring instead of buying the whole tcase. Looks pretty easy installing the toner ring according to this manual from a Ford. Its correct that Dana 70's are Dana 70's right? There's no difference in the toner ring or setup from a Ford or Dodge Dana 70? I think the hardest part is going to be drilling the hole in the correct place and getting it to position correctly. I was reading a few forums seems like a straight forward setup. It will also give me some time and space to setup the yoke for the axle. Thanks for the help! Also when buying tone ring it also says there is an exciter ring? What the **** is that?
Old Mar 16, 2015 | 03:07 AM
horatio102's Avatar
horatio102
Why on earth wouldn't you have just bought a D70 out of a ram?
Old Mar 16, 2015 | 10:26 AM
ryan0714's Avatar
ryan0714
i got a d70 out of a ram 2500 v10 and all you had to do was take the speed sensor from the 9.25 axle and put it into the hole on the d70 :P
Old Mar 16, 2015 | 12:05 PM
Moparite's Avatar
Moparite
I'm still trying to figure out why put a d70 in a 1500? A bit of overkill.
Old Mar 16, 2015 | 12:06 PM
dman12323's Avatar
dman12323
There very Rare down here and people who are selling them are asking $1,000 per axle or even more and that's used. I guess they have high sentimental value since they come from under a dodge. Enable for anybody down here to switch to Dana 60 or 70 we have to literally make it fit under a vehicle. For the front unless I want to pay $1500 with broken gear set im going to have to cut the coil bucket brackets off my Dana 44 and reweld them on to a working D60 for like $250 that I picked up. I guess I could have always made the 38's work with 1/2 ton axles ,built up the Dana 44 and chrysler 9.25 is okay nothing special. But they were able to hold up to jumping,dropping,flexing, one wheel spin and touching the ground and mudding and only broke the 9.25 1 time and that was when I ran 35's haha. My front ball joints are going so I just decided to go to 8 lug both front and rear and happened to pickup the rear first.
Old Mar 16, 2015 | 12:10 PM
dman12323's Avatar
dman12323
This is why: And imagine this is only with 35's lol
