Warmer weather causing long crank?
Old Apr 21, 2015 | 07:51 AM
  #31
Beg/borrow/rent a fuel pressure test gauge from your local parts store. First thing in the morning, put the gauge on the truck, crank the engine, see what your fuel pressure does. If it immediately comes up to 50PSI, but, the engine still doesn't fire, fuel isn't the problem.
Old Apr 21, 2015 | 07:22 PM
  #32
BrandonBuc'em's Avatar
BrandonBuc'em
where is the hook up for the fuel pressure gauge? its a 5.2
Old Apr 21, 2015 | 07:59 PM
  #33
mda8569's Avatar
mda8569
Shrader valve on fuel rail, driver side.
Old Apr 21, 2015 | 10:33 PM
  #34
BrandonBuc'em
mine doesnt have a shrader valve
Old Apr 22, 2015 | 12:00 AM
  #35
ReadRam's Avatar
ReadRam
I think you have to hook up to the fuel line disconnect with an adapter. Someone will correct me though.
Old Apr 22, 2015 | 06:56 AM
  #36
mda8569's Avatar
mda8569
Wow, didnt know that the earlier models dont have that valve. I would guess that you would pull the supply line and use an adaptor in-line.
Old Apr 22, 2015 | 06:12 PM
  #37
BBartow's Avatar
BBartow
They do
Old Apr 22, 2015 | 06:46 PM
  #38
97 is kinda the red-headed step-child. Plastic fuel rail didn't have the test port. All the steel fuel rails do though.
Old Apr 28, 2015 | 07:03 PM
  #39
BrandonBuc'em
been pretty busy fellas. ill update this thread with some after i replace a few sensors and if need be swap out the fuel pump. thanks for all the help guys
Old Jul 13, 2015 | 12:33 AM
  #40
eddiekimberly's Avatar
eddiekimberly
Any solutions ever come from this forum? I am still having the issue and am nowhere.
