Drive line noise
Old Apr 14, 2015 | 10:26 AM
BigRedRam95's Avatar
BigRedRam95
Default Drive line noise
Hey guys it's been along time sence I've been on. I just got back into driving my 1500. It's hard to say no to all the power that cummins has to offer. But thought I should drive the old ram some. I'm having a noise in the drive line. I'm thinking it's from the transfer case. When I put the truck in gear I get a clunk. When I get off the throttle I get a clunk. It's not like a chain skipping teeth. Could it be slack in the tcase or maybe a broken snap ring? Just looking for any help. The truck just rolled over 95000.
Old Apr 14, 2015 | 10:33 AM
Check u-joints in the rear driveshaft first. Then have a look at the rear pinion. See if all that is ok.
Old Apr 14, 2015 | 01:59 PM
BigRedRam95
A few years ago I broke the bolts that hold the rear u joint in and it shoved the slip joint all the way into the tcase. I replaced all the u joints then and have only put maybe 3000 miles on them.
I also had the 4.10s put in a few years ago they seem to be noise free.
Old Apr 14, 2015 | 08:09 PM
I would check 'em anyway. Just for giggles. (and, it's easy.)
If they seem ok, drop the driveshaft, pull the tailhousing off the t-case, and check the snap ring. (you can also check chain slop at that point.)
Old Apr 15, 2015 | 09:11 PM
UnregisteredUser's Avatar
UnregisteredUser
Going to all that bother, I recommend adding a few minutes more and installing a transfer case saver.
And here's why:
A borked snap ring will cause that, but you're not going to break a transfer case saver.
Old Apr 16, 2015 | 12:29 PM
BigRedRam95
Where is the best place to get the case saver
Old Apr 16, 2015 | 01:24 PM
UnregisteredUser
Follow the link in my post.
Old Apr 26, 2015 | 02:44 PM
BigRedRam95
Well I pulled the driveshaft today. I found the output shaft housing has both top bolt ears broke off. The snap ring was not broken. I went ahead and took it off and installed the tcase saver. How much play should be in the output shaft. The bearing is good but when I spin it left and right it has maybe an 1/8 inch of play before it turns the front drive shaft. The case seams to be leaking at all the splits. How big of a deal is it to split the case and reseal everything?
Old Apr 26, 2015 | 09:01 PM
That's actually pretty good...... Not very much slop at all.
I don't think there is a gasket between case halves...... sure wouldn't hurt to drop it out, open it up, clean it out, and reseal it. Having a jack to help makes it easier. Not too bad of a job.
Old Apr 26, 2015 | 10:40 PM
Ham Bone's Avatar
Ham Bone
the cases are sealed with rtv from the factory
