Dual acting Axle Seals offered @???
Old Apr 22, 2015 | 06:56 PM
BlackieLawless's Avatar
BlackieLawless
Default Dual acting Axle Seals offered @???
Hi all,
Done a bit of mudding in my time & have always had to flush out my Diff Case Housing & tubes repeatedly afterwards which proved costly and time consuming to say the least. Vowing to replace my axel seals w/ double acting ones eventually it has now become a more urgent need but can't remember for the life of me where I was told I could find them for my Dana 44 front and 9-1/4 rear. Can anyone point me in the right direction???? Thanks for reading and offering any suggestions or help is always appreciated!
Old Apr 22, 2015 | 08:46 PM
ssomer's Avatar
ssomer
I know the g2 outer seals will work for the front 44 but have no clue on rear
Old Apr 23, 2015 | 09:04 AM
Moparite's Avatar
Moparite
Water/dirt get in the axle from submerging it under water. It gets in through the vent not the axle seals. The outer seals for the front help keep the crap from building up in the axle tube. You may want to install these...
http://www.northwestfab.com/Creeper-...Kit_p_623.html
Old Apr 23, 2015 | 09:11 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by BlackieLawless
Hi all,
Outer seals are mostly from aftermarket. You may never actually stop it though because most fluid gets pulled in right at the diff cover. Hot oil and housing hits cold water and it sucks the water in from the thermal shock. Doing a good gasket is the key there, plus having a breather that is working correctly, length and clear.
D44 outer seal choices:
http://www.rcvperformance.com/produc...aspx?sku=D44SK
http://www.4wd.com/Jeep-Drivetrain-J...FYWVfgodyFUAOA
None for the 9.25", especially since it's a semi-float axle and no aftermarket gives a crap about it.
Old Oct 19, 2015 | 09:04 PM
armynurse's Avatar
armynurse
Has anyone here used these axle tube end seals on their Ram 1500 Dana 44 front axles? My passenger side is leaking, and while they have it apart to replace the inner seal (yes; I know it's just a dustcap on the end) I'd like to put something like these on the ends.
I've got these on the ends of the Dana 30 on my TJ and ZJ, but don't know if they'd fit on my half-ton's Dana 44.
Old Oct 20, 2015 | 09:55 AM
Think I would call the manufacturer of the seals you have pictured there, and ask them if they make them for D44 axles. Looks like a REALLY good idea to me. I think the current design for the seals is just farking stupid.
Old Oct 21, 2015 | 07:38 AM
Moparite's Avatar
Moparite
http://www.sealsit.com/jeep-axle-seal.html
Old Oct 25, 2015 | 09:09 PM
armynurse's Avatar
armynurse
So... I'm assuming by the lack of responses that NOBODY here has put a set of axle tube end seals on their Gen 2 Dodge Ram (not Jeep!) Dana 44 front axles?
