46RE rebuild in progress...
Old 05-09-2015, 09:23 AM
Moparite's Avatar
Moparite
Moparite is offline
Does it block the blue highlighted words in the posts also? Have to look into it! Better yet, Get rid of the ads! I usually hit stop before they have time to load.
Old 05-09-2015, 09:53 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,197 Likes on 2,949 Posts
Blue highlight words??? What you talkin' about Willis?
If you are referring to the "Like", and "Share", nope, those are still there.
Old 05-09-2015, 08:29 PM
Moparite's Avatar
Moparite
Moparite is offline
See pic, Blue words(ad links).
Old 05-09-2015, 09:38 PM
That's weird. I don't see that...... is it a link to a description or something?
Old 05-09-2015, 10:30 PM
34blazer's Avatar
34blazer
34blazer is offline
It's adware embedded on the page, I just downloaded ad blocker plus for IE and it works.
Old 05-10-2015, 02:40 AM
horatio102's Avatar
horatio102
horatio102 is offline
When I was a mod on another forum, that crap was blocked for the moderators and the paid members.
Old 05-10-2015, 02:48 AM
horatio102's Avatar
horatio102
Originally Posted by 34blazer
Can you elaborate on those errors?
The ones I remember off the top of my head, from rebuilding my 47re:
Case ID - according to the pictures in the book, both of the 47re cases I had sitting in front of me (out of a 98 and a 99 Cummins) were actually 48re cases due to fluid passages.
Torque converter depth - the book says the torque converter face should be ~3/4" recessed behind the face of the trans case. Not so, at least on the diesels.
Number of OD clutches - it says the diesels have one more friction and one more steel, along with a flat reaction plate, versus the stepped one for the gas trucks. Not true. Both of my transmissions were out of Cummins trucks, and both had the "gas" OD clutch setup.
You'd think the ATSG might get the info correct on a transmission that's been out of production for what, 8 years now? Clearly it's not a priority for them.
Old 05-11-2015, 12:12 AM
34blazer's Avatar
34blazer
34blazer is offline
Thanks for the info!
While installing the superior reverse super servo today I broke the support ring, M-F'er...
Now I cant find a distributer to replace it, looks like im going to need to buy another servo just for the damn support ring.
http://www.superior-transmission.com...age.cfm?ID=184
Old 05-11-2015, 02:53 PM
Try here.
Old 05-11-2015, 09:50 PM
34blazer's Avatar
34blazer
34blazer is offline
they don't have the seal kit, but, I can return the old one and Rick said he will refund it, since I bought everything from WIT. Good company to deal with, for sure.
Quick Reply: 46RE rebuild in progress...
