speed sensor conversion??
Old May 10, 2015 | 10:31 AM
  #21
I think to fix your speedo, and trans issues, you are going to have to replace the t-case with a 94-97 unit. That will actually have the provision for the VSS.
But.... Your trans has a mechanical governor...... 1st-3rd should shift appropriately, regardless of what electronics are there/not there. Unless it is the wrong trans as well......
Check the connector that goes down into the top of the valve body, probably need a mirror to see into it.... how many pins? (I am going to guess.... 8, which is just wrong for your truck.)
Old May 11, 2015 | 11:34 AM
  #22
CHYZDAD's Avatar
CHYZDAD
will do that after work.
BTW what relays/fuses are utilized in making this monster work
Old May 11, 2015 | 04:54 PM
  #23
CHYZDAD's Avatar
CHYZDAD
Will also try and get a pic of the tran pan...maybe that will help determine the right trans.
Old May 11, 2015 | 04:56 PM
  #24
They all look alike. The only external difference is the connector for the trans electronics.... RH is 3 pin, RE is 8 pin.
Old May 11, 2015 | 05:07 PM
  #25
CHYZDAD's Avatar
CHYZDAD
K...thanks...gonna let the truck cool down a bit before i climb under it. I will let ya know what i find...
Keeping fingers crossed
Old May 11, 2015 | 07:15 PM
  #26
CHYZDAD's Avatar
CHYZDAD
Alright....the good news isi found the connector i think. If its round. Than i did. Just below the shift linkage. And 8 pins. Not my night
Old May 12, 2015 | 09:39 AM
  #27
That's a 96 or newer trans, and explains why you have no automatic functions.......
Two choices here:
1: Upgrade wiring to 96-97 OBDII computer. Not too much of an ordeal, but, you will still need to replace the t-case, as speedo info started coming from just the rear wheels speed sensor in 98 (or 99?), and too much other stuff changed to make THAT conversion workable......
2. Find a trans/t-case out of a 94-95 truck....... (t-case can be 94-97)
3.... Always an option as well..... Manual trans conversion. Still need the 94-97 t-case though.
Old May 12, 2015 | 01:32 PM
  #28
CHYZDAD's Avatar
CHYZDAD
so either option I choose I will still have a fair amount of work to do. Well I appreciate the help. Looks like I need to go do some shopping.
Old May 12, 2015 | 04:48 PM
  #29
CHYZDAD's Avatar
CHYZDAD
Well....been trying to source a 95 core for decent money...hahaha...what a joke. EVen if i did find one it would cost an arm and a leg to do a full rebuild on it. So im at 1400...
Im sourcing the wireharnes swap and see if it will be much different or even feasible to do. I have heard of it being done on older trucks...not that this one new. The pcm might be my biggest expense...not counting my time rerun the whole thing.
Old May 12, 2015 | 05:15 PM
  #30
Where ya at? I have a 46RH core out in the barn...... it would HAVE to be rebuilt..... but, I'd let it go cheap.
